SSL1.50SV-BS
SSL1.50SV-BS
    TECHFLEX
    1-1/2" STAINLESS STEEL XC 100'
SSL1.50SV-BS 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet stainless steel Put-Ups V  irtually Indestructible 304 Stainless Steel Nominal Size W  ill Not Discolor Or Rust 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” R  esists Abrasion, Chemicals And UV E  asy To Install C  uts With Shears Or Serrated Scissors H  alogen Free Cut Cleanly Shears Material 304 Stainless Steel Grade SSL Expansion Range Min Max SSL0.13SV 1/16” 11/32” SSL0.25SV 3/16” 13/32” SSL0.38SV 1/4” 5/8” SSL0.50SV 3/8” 3/4” SSL0.75SV 1/2” 1 1/4” SSL1.00SV 5/8” 1 5/16” SSL1.25SV 3/4” 1 3/4” SSL1.50SV 1” 2 1/8” Wall Thickness Wire Thickness Bulk Spool Shop Spool Available Colors Lbs/ 100’ .013” .013” .013” .013” .013” .025” .025” .025” .005” .005” .005” .005” .005” .010” .010” .010” 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ Silver Silver Silver Silver Silver Silver Silver Silver 1.20 2.20 2.54 3.15 6.90 9.78 13.70 16.60 Braided Stainless Steel XC, Tight Weave for Extra Coverage Our new X-tra Coverage product, Stainless Steel XC, provides fuller coverage with no transparent elements in the braided construction and results in a continuous stainless steel shine on any application. Nothing protects hoses from wear and blowout quite like real Stainless Steel braid. It looks great in any application and is as strong as, well, steel. But, custom hoses overbraided with stainless steel are expensive, selections are often limited and production and delivery times can be an issue. Now, you can take any stock or custom hose, slip a length of Flexo® Stainless over it, hide the cut ends under your clamps and have the same look and protection as custom overbraided hoses at a fraction of the cost. Flexo® Stainless XC is pre-rounded for easy, slip on installation and is available in diameters and expansion ranges to accommodate virtually any common hose or wire application. Wire Thickness .005” - .010” Drawing Number TF001SS-WD www.techflex.com Part # 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Braided Stainless Steel XC sleeving is used in applications where constant movement and high temperatures require a flexible, indestructible covering. Nominal Size Part # 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” SSL0.13SV SSL0.25SV SSL0.38SV SSL0.50SV SSL0.75SV SSL1.00SV SSL1.25SV SSL1.50SV AWG Carriers Wires/ of Ends Carrier 36 36 36 36 36 30 30 30 24 24 48 48 48 48 48 48 5 13 7 11 15 7 10 12 Total Ends 120 312 336 528 720 336 480 576 Colors Available: Silver (SV) METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet stainless steel Melt Point ASTM D-2117 2,650°F (1,454°C) FLAMMABILITY www.techflex.com Rating______________________ Non Flammable CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________________ 1 Aliphatic Solvents___________________________ 1 Chlorinated Solvents________________________ 1 Weak Bases________________________________ 1 Salts______________________________________ 2 Strong Bases_______________________________ 2 Salt Water 0-S-1926__________________________ 2 Hydraulic Fluid MIL-H-5606___________________ 1 Lube Oil MIL-L-7808_________________________ 1 De-Icing Fluid MIL-A-8243____________________ 1 Strong Acids_______________________________ 2 Strong Oxidants____________________________ 2 Esters/Ketones_____________________________ 1 UV Light__________________________________ 1 Petroleum_________________________________ 1 Fungus ASTM G-21__________________________ 1 Halogen Free____________________________ Yes RoHS___________________________________ Yes PHYSICAL PROPERTIES Wire Thickness_______________________ .005”-.010” ASTM D-204 Flammability Rating______________ Non Flammable Recommended Cutting___________________ Shears Colors______________________________________1 Wall Thickness________________________ .013”-.025” Abrasion_________________________________High Specific Gravity ASTM D-792__________________ NA Moisture Absorption________________________ NA % ASTM D-570 Hard Vacuum Data_____________________________ ASTM E-595 TML______________________________________ .00 CVCM____________________________________ .00 WVR______________________________________ .00 Outgassing___________________________ Very Low © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
SSL1.50SV-BS
物料型号:SSL0.13SV、SSL0.25SV、SSL0.38SV、SSL0.50SV、SSL0.75SV、SSL1.00SV、SSL1.25SV、SSL1.50SV
器件简介:FLEXO®不锈钢XC是一种几乎坚不可摧的304不锈钢编织管,具有连续的不锈钢光泽,适用于任何应用,并且具有出色的耐磨损和防爆性能。
引脚分配:表格中列出了不同型号的AWG线规、载体数、每载体线数和总端数。
参数特性:不锈钢丝厚度为0.005"-0.010",耐温性能、耐化学性能、物理性能等。
功能详解:FLEXO®不锈钢XC提供完整的覆盖,没有透明元素,易于安装,并且具有高耐磨损性和防爆性能。
应用信息:适用于需要保护软管免受磨损和爆裂的应用,如液压软管、电线等。
封装信息:提供不同直径和扩展范围的尺寸,以适应各种常见的软管或线缆应用。
颜色为银色(SV),并且产品符合RoHS标准,不含卤素,无SVHC(高度关注物质)。
SSL1.50SV-BS 价格&库存
很抱歉,暂时无法提供与“SSL1.50SV-BS”相匹配的价格&库存,您可以联系我们找货
