EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
Put Ups
E
asily Covers Irregularly
Shaped Set Ups
E
asily Secured With
Wire Ties or Hose Clamps
Nominal
Size
Part
Wall Thickness
±0.010”
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
3 1/2”
FIF3.50
.094"
50’
25’
SV, RD, BK
16.53
Protects From Extreme
Heat, Open Flame, and
Molten Splash
High Temp, Silicone Coated
Fiberglass Hose Wrap
Fireflex Flat provides the same protection against
exposure to extreme heat, open flame, and molten
splash as the Fireflex Sleeve, but in a versatile tape.
It is specifically designed to protect components
of irregular shape, such as hose splitter
assemblies and cable splices. The heavy silicone
coating maintains flexibility while resisting all
automotive chemicals and solvents, and providing
an increased level or abrasion protection.
Cut Cleanly
Scissors
Material
Silicone Coated Fiberglass
It is common for Fireflex Flat to be over-wrapped
at 50%, providing a double layer of protection.
Once installed, it can be easily secured with
tie-wraps, wire ties, and hose clamps.
Grade
FIF
The versatility of this tape allows for covering
almost any irregular shape.
Wall Thickness
.094"
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
Red (RD), Silver (SV),
Black (BK)
EXTREME
TEMPERATURE
Melt Point
ASTM D-2117
ABRASION
Rating_______________ Non Flammable
High
Mil-I-23053
Abrasion Test Machine
500°F (260°C)
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 1
Strong Oxidants___________________ 2
Esters/Ketones____________________ 2
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC______________________________
Minimum Continuous
-65°F (-54°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
ASTM D-204
Flammability Rating___ Non Flammable
Recommended Cutting________Scissor
Colors__________________________ 3
Wall Thickness_________________ .094”
Tensile Strength (Yarn)_______ Ex. High
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_______NA
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“FIF3.50SV”相匹配的价格&库存,您可以联系我们找货
