KVX1.00YL
KVX1.00YL
    TECHFLEX
    1" ARAMID ARMOR, YELLOW, 200'
KVX1.00YL 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups H  igh Cut Resistance W  ill Not Melt, Burn Or Support Combustion L ight Weight R  esists Acids, Bases, Solvents, and Fuels Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 1/2” 1” 1 1/4” KVX0.13BK KVX0.25 KVX0.50 KVX1.00 KVX1.25 1/8” 1/4” 1/2” 1” 1 1/4” 1/4” 3/8” 1” 1 3/4” 2” 500’ 500’ 250’ 200’ 125’ 100’ 50’ 50’ 25’ 25’ Black BK & BK & BK & BK & 1.02 1.69 3.22 4.76 5.88 BK YL YL YL YL H  igh Tensile Strength Soft, Lightweight, and Extraordinarily Strong Cut Cleanly Flexo® Aramid Shears Material *Kevlar® Aramid Fibers Grade KVX Extra heavy duty, tightly woven Aramid Armor® is braided from aramid fibers, soft and pliable but with 5 times strength of steel on equal-weight basis. Aramid Armor® is perfect for bundling and protecting vulnerable components from the most extreme environmental conditions. The aramid fibers provide durability, pliability and extraordinary tensile strength. It will not melt, burn or support combustion. The inherent strength and heat resistance of Aramid Armor® provides performance that can not be worn or aged away. Typical uses include aerospace, marine, and automotive industry applications. Aramid Armor® sleeving is available in Yellow. Colors Available: Yellow (YL) and Black (BK). Whenever your sleeving needs superior cut protection, the cut and fire resistant properties of Aramid Armor® will fill that need. Wall Thickness 0.052” Drawing Number TF001KV-WD *Kevlar® is a registered trademark of DuPontTM. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: Black (BK) & Yellow (YL) ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION Maximum Continuous Abrasion Resistance Mil-I-23053 320°F (160°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Scuffing And Pulling Of Soft Fibers 20 Test Cycles Scuffing And Pulling Of Fibers Continues 400 Test Cycles Material Destroyed 700 Test Cycles Pre-Test Weight 5,730.5 mg Post-Test Weight 5,200.1 mg Test End Loss Of Mass Point Of Destruction 530.4 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________ 2 Aliphatic Solvents___________________ 2 Chlorinated Solvents________________2 Weak Bases________________________ 1 Salts______________________________ 1 Strong Bases_______________________ 2 Salt Water 0-S-1926__________________ 1 Hydraulic Fluid MIL-H-5606____________ 1 Lube Oil MIL-L-7808__________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids_______________________ 2 Strong Oxidants____________________2 Esters/Ketones_____________________2 UV Light _________________________ 4 Petroleum_________________________ 1 Fungus ASTM G-21__________________2 Halogen Free____________________ Yes RoHS____________________________Yes Minimum Continuous -274°F (-170°C) PHYSICAL PROPERTIES Monofilament Diameter__________ NA ASTM D-204 Cutting__________ Flexo Aramid Shears Colors___________________________ 2 Wall Thickness_________________0.052” Tensile Strength (Yarn)_____________ 39 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 1.44 Moisture Absorption %______________ ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 at 10-5 torr TML__________________________3.13 CVCM_________________________ .19 WVR___________________________ .76 Smoke D-Max_____________________ ASTM E-662 Outgassing ___________________ _High Oxygen Index_____________________29 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06-21 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Medium
KVX1.00YL 价格&库存
很抱歉,暂时无法提供与“KVX1.00YL”相匹配的价格&库存,您可以联系我们找货
