FSN0.50SV164
FSN0.50SV164
    TECHFLEX
    FLEXO SHIELD 1/2" SILVER 164'
FSN0.50SV164 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet Put-Ups E  conomical & Easy To Install C  ut & Abrasion Resistant E  xtremely Flexible And Lightweight F  lame Retardant C  uts With Shears E  xcellent EMI Shielding (1 MHz To 1 GHz) Nominal Size Part # Wall Thickness *1/8” *3/8” *1/2” *3/4” 1” 1 1/4” 1 1/2” FSN0.13SV FSN0.38SV FSN0.50SV FSN0.75SV FSN1.00SV FSN1.25SV FSN1.50SV .013” .013” .013” .013” .025” .025” .025” Expansion Range Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/16” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1/4” 1/2” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 328’ 328’ 328’ 328’ 328’ 328’ 328’ 164’ 164’ 164’ 164’ 164’ 164’ 164’ Silver Silver Silver Silver Silver Silver Silver 0.74 1.38 2.09 2.80 2.90 3.40 3.90 High Temperature Shielded Expandable Sleeving Flexo® Shield is a high performance EMI (Electromagnetic Interference) shielded, braided expandable sleeving. Flexo® Shield is cut and abrasion resistant, flexible and lightweight. Our sleeving can help fulfill the requirements of the internationally recognized standard CISPR25 for frequencies ranging from 10 KHz to 1 GHz. It does this by assisting in the shielding of wires that are attached to these electronic components which require this rating. The material is also great for hose covering on hot rods and motorcycles. Cut Cleanly Shears Material Aramid & Tinned Copper Grade FSN Monofilament Diameter .010” Drawing Number TF001FSN-WD * = VW-1 Sizes 1/8" - 3/4" Colors Available: Silver (SV) With its high temperature aramid fiber cores and low angle braid, Flexo® Shield can expand and contract to a limited degree to create a perfect fit. Flexo® Shield braid fibers create a sleeve that provides good EMI protection and yields a material with out- standing flex-life. Flexo® Shield is great for applications where light weight and high performance are needed such as: computer systems, electronic office equipment, medical electronics, communication systems and many more. Techflex® Flexo® Shield is intended for high flex, high temperature, and environmentally tough applications, therefore making it appropriate for several aerospace applications. Flexo® Shield sleeving is used where light weight, high performance, high flex and high temperature are needed. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 VW-1 METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet PHYSICAL PROPERTIES CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases_____________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 RoHS___________________________Yes ASTM D-2117 449°F (232°C) Maximum Continuous Mil-I-23053 302°F (150°C) Minimum Continuous -40°F (40°C) FLAMMABILITY Rating_____________________ UL, VW-1 SHIELDING EFFECTIVENESS (E-FIELD) * Attenuation levels reduced approximately 20% when used in maximum expanded state Attenuation data was derived using procedures defined in Mil-STD-295. © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Monofilament Diameter________ .010" ASTM D-204 Flammability Rating______________ UL Recommended Cutting________ Shears Colors__________________________1 Wall Thickness___________ .013"-.025" Abrasion_____________________ Low Melt Point
FSN0.50SV164 价格&库存
很抱歉,暂时无法提供与“FSN0.50SV164”相匹配的价格&库存,您可以联系我们找货
