FMS1.50FK-BK
FMS1.50FK-BK
    TECHFLEX
    FLEXO MNTNG SYS FNSHNG PK BLK
FMS1.50FK-BK 数据手册
HOW TO INSTALL FLEXO MOUNTING SYSTEM... The Ultimate Termination Solution For Flexo Sleeving Easy Field Installation • Universal Screw Mount • Easy Clip, No Special Tools Required Fits In Single Gang Wall Box • Super Strong Strain Relief For Your Wires At the heart of the FMS is the Locking Collar, which when used in conjunction with the Metal Retaining Ring, permanently holds the sleeve. Before... After. When used in conjunction with the Techflex sleeving, the FMS creates a lasting and attractive terminated assembly. 104 Demarest Road • Sparta, NJ 07871 • 1-973-300-9242 • Toll Free 1-800-323-5140 www.Techflex.com HOW TO INSTALL FLEXO MOUNTING SYSTEM... Our new patented Flexo Mounting System (FMS) has been created to attractively terminate applications with a secure mountable end. This new Mounting System is engineered to work great with Flexo PET 1½” & 1¾”, and with Flexo Clean Cut 1½”. The installer friendly part clamps securely onto the sleeve without attaching to your wiring for ideal strain relief. The two piece construction removes any limitations in size created by large connectors and preserves the sleeving’s expandability. Automotive grade glass filled nylon construction is suitable for a variety of applications. Step 1 Install the sleeving over your wire bundle. Try to closely match the sleeving diameter to your bundle diameter so the bundle is fairly tightly managed. Leave about 2” of additional length to put through to the other side of the finished assembly. Step 4 Hold it in place while you align the other half of the locking collar to the locking tabs on the ends of both halves. Squeeze the 2 halves together until both ends snap and lock together. Step 2 Open the metal retaining ring and slide it over your bundle. Install the ring INSIDE of the sleeving so that the registration teeth protrude through the sleeving. Step 5 Smooth out the sleeving to allow the wall plate to easily slide up the length of the cable bundle. Slide the wall plate onto the assembly so that the side that faces the wall is against the locking collar. Snap the locking collar over the registration pins on the inside of the wall plate. Step 3 Take one of the locking collar halves and place it over the teeth on the retaining ring. It is important that the teeth of the retaining ring protrude into the appropriate holes in the locking collar. Step 6 Screw the wall plate into the workbox with the color matched screws, included. Congratulations! You now have a strong and attractive cable management solution that will stay secure for years. Part # Description Available Colors Lbs/ Pkg. FMS1.50FL Packaging of a Single Locking Collar Black (BK) 0.03 FMS1.50FL5 Packaging of 5 Pc. Locking Collar Black (BK) 0.15 FMP1.50PLATE Wall Plate only (includes 2 screws) Black (BK), Almond (BE) & White (WH) 0.09 FMS1.50FK Finishing Pack: 1 Locking Collar & 1 Wall Plate Black (BK), *Almond (BE) & *White (WH) (*Plate only) 0.12 104 Demarest Road • Sparta, NJ 07871 • 1-973-300-9242 • Toll Free 1-800-323-5140 www.Techflex.com
FMS1.50FK-BK 价格&库存
很抱歉,暂时无法提供与“FMS1.50FK-BK”相匹配的价格&库存,您可以联系我们找货
