166-90103
166-90103
    HELLERMAN(海尔曼太通)
    HELAGUARD-IP66FITTING,STRAIG
166-90103 数据手册
166-90103 Article Number: 166-90103 Description: HelaGuard Non-Metallic IP66 Fitting, Straight, NPT Thread, 0.38" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90103 Type HG038-S-0380 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Straight fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP66 Fitting, Straight, NPT Thread, 0.38" Dia, PA66, Black, 10/pkg Length L (Imperial) 1.61" Length L (Metric) 41mm Bore Diameter (Imperial) 0.43" Bore Diameter (Metric) 11.0mm Clearance Hole Diameter (Imperial) 0.657" Clearance Hole Diameter (Metric) 16.7mm Euro (NW) Size 12mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.43" Thread Type NPT Trade Size 3/8 " Variant Straight Product Dimensions generated on: 5/10/2017 166-90103 Product Dimensions Outside Diameter D (imperial) 1.14" Outside Diameter D (metric) 29mm Nominal Diameter (Imperial) 3/8" Nominal Diameter (Metric) 16mm Thread Length (metric) 11mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90103 价格&库存
很抱歉,暂时无法提供与“166-90103”相匹配的价格&库存,您可以联系我们找货
