166-90238
    HELLERMAN(海尔曼太通)
    HELAGUARD-CONDUITEND1.00"FL
166-90238 数据手册
166-90238 Article Number: 166-90238 Description: HelaGuard REC Conduit End Cap, 1.00" Dia, Flexible Rubber, Black, 10/pkg Base Data Local Order Number 166-90238 Type REC1000 Color Black (BK) Features and benefits ‡Flexible rubber material easily slips over end of conduit to seal out dust and debris. ‡Diameter markings make it easy to cut down to appropriate size. ‡Contains a cable tie slot for extra retention when required. Quantity Per pack Product Description Rubber cap easily slides over un-terminated conduit and tubing ends to protect inside wire and cable bundles from debris. For use with HelaGuard conduits and tubing. Short Description HelaGuard REC Conduit End Cap, 1.00" Dia, Flexible Rubber, Black, 10/pkg Length L (Imperial) 1.67" Length L (Metric) 42.3mm Fits Conduit Size (Imperial) 1" Fits Conduit Size (Metric) 34mm Outside Diameter D (imperial) 1.67" Outside Diameter D (metric) 42.5mm Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 34mm Material Rubber Material Shortcut CR Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +248°F (-50°C to +120°C) Product Dimensions Material and Specifications generated on: 5/10/2017 166-90238 Material and Specifications ROHS Compliant Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90238 价格&库存
很抱歉,暂时无法提供与“166-90238”相匹配的价格&库存,您可以联系我们找货
