166-90122
166-90122
    HELLERMAN(海尔曼太通)
    HELAGUARD-IP68FITTING,STRAIG
166-90122 数据手册
166-90122 Article Number: 166-90122 Description: HelaGuard Non-Metallic Fitting, IP68, Straight, 1.25" NPT Thread, 1.25" Dia, PA66, Black, 2/pkg Base Data Local Order Number 166-90122 Type HGL125-S-1250 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Straight fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic Fitting, IP68, Straight, 1.25" NPT Thread, 1.25" Dia, PA66, Black, 2/pkg Length L (Imperial) 2.36" Length L (Metric) 60.0mm Bore Diameter (Imperial) 1.28" Bore Diameter (Metric) 32.5mm Clearance Hole Diameter (Imperial) 1.649" Clearance Hole Diameter (Metric) 41.9mm Euro (NW) Size 36mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.63" Thread Type NPT Trade Size 1-1/4 " Variant Straight Product Dimensions generated on: 5/10/2017 166-90122 Product Dimensions Outside Diameter D (imperial) 2.48" Outside Diameter D (metric) 63.0mm Nominal Diameter (Imperial) 1-1/4" Nominal Diameter (Metric) 42mm Thread Length (metric) 16mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Listed (US) Yes UL Listed (US and Canada) Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 2 Package Quantity (Metric) 2Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90122 价格&库存
很抱歉,暂时无法提供与“166-90122”相匹配的价格&库存,您可以联系我们找货
