166-90108
Article Number:
166-90108
Description:
HelaGuard Non-Metallic IP66 Fitting, Straight, NPT Thread,
1.50" Dia, PA66, Black, 2/pkg
Base Data
Local Order Number
166-90108
Type
HG150-S-1500
Color
Black (BK)
Features and benefits
External NPT thread provides a secure connection.
Snap-on construction reduces installation time and costs by eliminating the need to
thread fittings onto conduits.
All-around "teeth" attach firmly to conduit and deliver a high extraction force.
Durable nylon material has high resistance to salts, oils, weak acids and solvents.
IP66 fitting has one-piece construction.
IP68 fitting has additional conduit seal for increased protection against wind, dirt
and water.
Quantity Per
bag
Product Description
Straight fitting features a snap-on design that provides a quick, secure connection.
Constructed of a very durable nylon material with a high resistance to salts, oils,
weak acids and solvents. Designed for easy removal with a small screwdriver.
Choose from IP66 or IP68 ingress protection rated fittings.
Short Description
HelaGuard Non-Metallic IP66 Fitting, Straight, NPT Thread, 1.50" Dia, PA66, Black,
2/pkg
Length L (Imperial)
2.64"
Length L (Metric)
67mm
Bore Diameter (Imperial)
1.65"
Bore Diameter (Metric)
42.0mm
Clearance Hole Diameter (Imperial)
1.882"
Clearance Hole Diameter (Metric)
47.8mm
Euro (NW) Size
48mm
Swivel Thread (Y/N)
No
Thread Length (Imperial)
0.71"
Thread Type
NPT
Trade Size
1-1/2 "
Variant
Straight
Product
Dimensions
generated on:
5/10/2017
166-90108
Product
Dimensions
Outside Diameter D (imperial)
2.99"
Outside Diameter D (metric)
76mm
Nominal Diameter (Imperial)
1-1/2"
Nominal Diameter (Metric)
54mm
Thread Length (metric)
18mm
Material
Polyamide 6.6 (PA66)
Material Shortcut
PA66
Flammability
UL 94 V2
Halogenfree
Yes
Operating Temperature
-58°F to +275°F (-50°C to +135°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
2
Package Quantity (Metric)
2Pieces
Customs Number(Schedule B)
3926909987
Material and
Specifications
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+440.349221+56.96590
