166-90097
166-90097
    HELLERMAN(海尔曼太通)
    45DEGREEELBOWTHREADEDIP661.
166-90097 数据手册
166-90097 Article Number: 166-90097 Description: HelaGuard Non-Metallic Fitting, IP66, 45-Elbow, 1.5" NPT Thread, 1.50" Dia, PA66, Black, 2/pkg Base Data Local Order Number 166-90097 Type HG150-45-1500 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic Fitting, IP66, 45-Elbow, 1.5" NPT Thread, 1.50" Dia, PA66, Black, 2/pkg Length L (Imperial) 4.17" Length L (Metric) 106mm Bore Diameter (Imperial) 1.54" Bore Diameter (Metric) 39.0mm Clearance Hole Diameter (Imperial) 1.882" Clearance Hole Diameter (Metric) 47.8mm Euro (NW) Size 48mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.63" Thread Type NPT Trade Size 1-1/2 " Product Dimensions generated on: 5/10/2017 166-90097 Product Dimensions Variant 45° Elbow Outside Diameter D (imperial) 2.99" Outside Diameter D (metric) 76.0mm Nominal Diameter (Imperial) 1-1/2" Nominal Diameter (Metric) 54mm Thread Length (metric) 16mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US) Yes UL Recognized (US and Canada) Yes Package Quantity (Imperial) 2 Package Quantity (Metric) 2Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90097
- 物料型号: 166-90097,型号为HG150-45-1500。 - 器件简介: 这是一个IP66等级的45度弯头配件,具有1.5英寸NPT螺纹和1.50英寸直径,材质为PA66(聚酰胺6.6),颜色为黑色。 - 引脚分配: 文档中未提及引脚分配,因为这是一个物理配件而非电子元件。 - 参数特性: 配件具有外部NPT螺纹以确保安全连接,快装式构造减少了安装时间和成本。弯头具有平滑的内腔,便于电缆安装。全方位的“牙齿”设计可以牢固地附着在导管上,并提供高拉拔力。耐用的尼龙材料具有高耐盐、油、弱酸和溶剂性。IP66配件为一体式构造,IP68配件则有额外的导管密封以增加对风、尘和水的防护。 - 功能详解: 弯头配件采用快装设计,提供快速且安全的连接。由非常耐用的尼龙材料制成,具有高耐化学性。设计便于用小螺丝刀轻松移除。可选择IP66或IP68防护等级的配件。 - 应用信息: 适用于需要耐化学腐蚀和高防护等级的环境。 - 封装信息: 产品尺寸包括长度、内径、外径等,每包含2个配件。
166-90097 价格&库存
很抱歉,暂时无法提供与“166-90097”相匹配的价格&库存,您可以联系我们找货
