166-90118
Article Number:
166-90118
Description:
HelaGuard Non-Metallic Fitting, IP68, Straight, 0.38" NPT
Thread, 0.38" Dia, PA66, Black, 10/pkg
Base Data
Local Order Number
166-90118
Type
HGL038-S-0380
Color
Black (BK)
Features and benefits
External NPT thread provides a secure connection.
Snap-on construction reduces installation time and costs by eliminating the need to
thread fittings onto conduits.
All-around "teeth" attach firmly to conduit and deliver a high extraction force.
Durable nylon material has high resistance to salts, oils, weak acids and solvents.
IP66 fitting has one-piece construction.
IP68 fitting has additional conduit seal for increased protection against wind, dirt
and water.
Quantity Per
bag
Product Description
Straight fitting features a snap-on design that provides a quick, secure connection.
Constructed of a very durable nylon material with a high resistance to salts, oils,
weak acids and solvents. Designed for easy removal with a small screwdriver.
Choose from IP66 or IP68 ingress protection rated fittings.
Short Description
HelaGuard Non-Metallic Fitting, IP68, Straight, 0.38" NPT Thread, 0.38" Dia, PA66,
Black, 10/pkg
Length L (Imperial)
1.61"
Length L (Metric)
41mm
Bore Diameter (Imperial)
0.43"
Bore Diameter (Metric)
11.0mm
Clearance Hole Diameter (Imperial)
0.657"
Clearance Hole Diameter (Metric)
16.7mm
Euro (NW) Size
12mm
Swivel Thread (Y/N)
No
Thread Length (Imperial)
0.43"
Thread Type
NPT
Trade Size
3/8 "
Variant
Straight
Product
Dimensions
generated on:
5/10/2017
166-90118
Product
Dimensions
Outside Diameter D (imperial)
1.14"
Outside Diameter D (metric)
29.0mm
Nominal Diameter (Imperial)
3/8"
Nominal Diameter (Metric)
16mm
Thread Length (metric)
11mm
Material
Polyamide 6.6 (PA66)
Material Shortcut
PA66
Flammability
UL 94 V2
Halogenfree
Yes
Operating Temperature
-58°F to +275°F (-50°C to +135°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
10
Package Quantity (Metric)
10Pieces
Customs Number(Schedule B)
3926909987
Material and
Specifications
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90118”相匹配的价格&库存,您可以联系我们找货
