166-90128
Article Number:
166-90128
Description:
HelaGuard Non-Metallic IP65 Fitting, 90-Elbow, NPT
Thread, 0.38" Dia, PA66, Black, 10/pkg
Base Data
Local Order Number
166-90128
Type
PSR038-90-0500
Color
Black (BK)
Features and benefits
External NPT thread provides a secure connection.
Twist-on installation makes future access fast and easy.
Internal spigot design helps ease threading of fitting onto conduit.
All-around ³teeth´attach firmly to conduit and deliver a high extraction force.
Durable nylon material has high resistance to salts, oils, weak acids and solvents.
IP65 rating for protection against wind, dirt and low pressure jets of water from all
directions.
Quantity Per
bag
Product Description
Compression fittings feature a twist-on design for easy installation and future
access. Constructed of a very durable nylon material with a high resistance to salts,
oils, weak acids and solvents. Fits HelaGuard non-metallic conduits and tubing.
Short Description
HelaGuard Non-Metallic IP65 Fitting, 90-Elbow, NPT Thread, 0.38" Dia, PA66,
Black, 10/pkg
Length L (Imperial)
2.01"
Length L (Metric)
51mm
Bore Diameter (Imperial)
0.41"
Bore Diameter (Metric)
10.5mm
Clearance Hole Diameter (Imperial)
0.827"
Clearance Hole Diameter (Metric)
21mm
Thread Length (Imperial)
0.51"
Trade Size
3/8 "
Outside Diameter D (imperial)
1.10"
Outside Diameter D (metric)
28mm
Nominal Diameter (Imperial)
3/8"
Nominal Diameter (Metric)
16mm
Thread Length (metric)
13mm
Product
Dimensions
generated on:
5/10/2017
166-90128
Material and
Specifications
Material
Polyamide 6.6 (PA66)
Material Shortcut
PA66
Flammability
UL 94 V2
Operating Temperature
-40°F to +248°F (-40°C to +120°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
10
Package Quantity (Metric)
10Pieces
Customs Number(Schedule B)
3926909987
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90128”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+582.9093150+75.41488
