166-90095
166-90095
    HELLERMAN(海尔曼太通)
    45DEGREEELBOWTHREADEDIP66.7
166-90095 数据手册
166-90095 Article Number: 166-90095 Description: HelaGuard Non-Metallic Fitting, IP66, 45-Elbow, 0.75" NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90095 Type HG075-45-0750 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic Fitting, IP66, 45-Elbow, 0.75" NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.87" Length L (Metric) 73.0mm Bore Diameter (Imperial) 0.75" Bore Diameter (Metric) 19.0mm Clearance Hole Diameter (Imperial) 1.039" Clearance Hole Diameter (Metric) 26.4mm Euro (NW) Size 23mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.59" Thread Type NPT Trade Size 3/4 " Product Dimensions generated on: 5/10/2017 166-90095 Product Dimensions Variant 45° Elbow Outside Diameter D (imperial) 1.73" Outside Diameter D (metric) 44.0mm Nominal Diameter (Imperial) 3/4" Nominal Diameter (Metric) 28mm Thread Length (metric) 15mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90095
- 物料型号:166-90095 - 器件简介:HelaGuard非金属配件,IP66防护等级,45度弯头,0.75英寸NPT螺纹,0.75英寸直径,PA66材质,黑色,每包10个。 - 引脚分配:文档中未提及引脚分配,因为这是一个物理配件而非电子元件。 - 参数特性: - 产品类型:HG075-45-0750 - 颜色:黑色(BK) - 特点和优势:外部NPT螺纹提供安全连接;快装结构减少安装时间和成本;弯头具有平滑的内孔,便于电缆安装;全方位“牙齿”牢固地附着在导管上,提供高提取力;耐用的尼龙材料对盐、油、弱酸和溶剂有很高的抵抗力。 - 产品尺寸:长度2.87英寸(73.0毫米),内径0.75英寸(19.0毫米),开孔直径1.039英寸(26.4毫米),欧标尺寸23毫米。 - 螺纹类型:NPT - 螺纹长度:0.59英寸 - 是否可旋转螺纹:否 - 材料:聚酰胺6.6(PA66) - 材料缩写:PA66 - 可燃性:UL94V2 - 无卤素:是 - 工作温度:-58°F至+275°F(-50°C至+135°C) - 符合ROHS:是 - UL认证(美国和加拿大):是 - UL认证(美国):是 - 功能详解:快装设计提供快速、安全的连接;由非常耐用的尼龙材料制成,对盐、油、弱酸和溶剂有很高的抵抗力;设计便于用小螺丝刀轻松移除;可选择IP66或IP68防护等级的配件。 - 应用信息:文档中未提供具体的应用信息,但根据其特性,这种配件可能用于需要耐化学腐蚀和高防护等级的工业环境中。 - 封装信息:每包10个。
166-90095 价格&库存
很抱歉,暂时无法提供与“166-90095”相匹配的价格&库存,您可以联系我们找货
