166-90173
Article Number:
166-90173
Description:
HelaGuard Non-Metallic IP66 Fitting, T-Connector, 0.38"
Dia, PA66, Black, 5/pkg
Base Data
Local Order Number
166-90173
Type
HG038-T
Color
Black (BK)
Features and benefits
Used to join conduits of same diameters and route to multiple directions.
Inspection lid facilitates cable pull through and eases installation.
Snap-on construction reduces installation time and costs by eliminating the need to
thread fittings onto conduits.
All-around "teeth" attach firmly to conduit and deliver a high extraction force.
Durable nylon material has high resistance to salts, oils, weak acids and solvents.
Vibration and shock tested to EN61373 Category 2.
IP66 fitting has one-piece construction.
IP68 fitting has additional conduit seal for increased protection against wind, dirt
and water.
Quantity Per
bag
Product Description
T- Connectors are used to join three same diameter corrugated conduits together,
and redirect cables into multiple directions. Constructed of a very durable nylon
material with a high resistance to salts, oils, weak acids and solvents. Designed for
easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection
rated fittings.
Short Description
HelaGuard Non-Metallic IP66 Fitting, T-Connector, 0.38" Dia, PA66, Black, 5/pkg
Length L (Imperial)
2.44"
Length L (Metric)
62mm
Bore Diameter (Imperial)
0.55"
Bore Diameter (Metric)
14.0mm
Euro (NW) Size
12mm
Swivel Thread (Y/N)
No
Trade Size
3/8 "
Variant
T-Connector
Outside Diameter D (imperial)
3.78"
Outside Diameter D (metric)
96mm
Product
Dimensions
generated on:
5/10/2017
166-90173
Product
Dimensions
Nominal Diameter (Imperial)
3/8"
Nominal Diameter (Metric)
16mm
Material
Polyamide 6.6 (PA66)
Material Shortcut
PA66
Flammability
UL 94 V2
Halogenfree
Yes
Operating Temperature
-58°F to +275°F (-50°C to +135°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
5
Package Quantity (Metric)
5Pieces
Customs Number(Schedule B)
3926909987
Material and
Specifications
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90173”相匹配的价格&库存,您可以联系我们找货
