166-90099
166-90099
    HELLERMAN(海尔曼太通)
    HELAGUARD-90DEGREENPTTHREAD
166-90099 数据手册
166-90099 Article Number: 166-90099 Description: HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90099 Type HG075-90-0750 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.60" Length L (Metric) 66mm Bore Diameter (Imperial) 0.75" Bore Diameter (Metric) 19.0mm Clearance Hole Diameter (Imperial) 1.039" Clearance Hole Diameter (Metric) 26.4mm Euro (NW) Size 23mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.59" Thread Type NPT Trade Size 3/4 " Product Dimensions generated on: 5/10/2017 166-90099 Product Dimensions Variant 90° Elbow Outside Diameter D (imperial) 1.73" Outside Diameter D (metric) 44mm Nominal Diameter (Imperial) 3/4" Nominal Diameter (Metric) 28mm Thread Length (metric) 15mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Listed (US) Yes UL Listed (US and Canada) Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90099
- 物料型号: 166-90099 - 产品描述: HelaGuard非金属IP66接头,90度弯头,NPT螺纹,直径0.75英寸,PA66材质,黑色,10个/包。 - 引脚分配: 该产品为90度弯头,具有NPT螺纹,贸易尺寸为3/4英寸。 - 参数特性: 材质为PA66,黑色,具有UL94V2阻燃等级,无卤素,工作温度范围为-58°F至+275°F(-50°C至+135°C),符合ROHS标准,已在美国和加拿大UL认证。 - 功能详解: 该弯头具有快装设计,提供快速、安全的连接。由非常耐用的尼龙材料制成,具有高耐盐、油、弱酸和溶剂性。设计便于用小螺丝刀拆卸,可选择IP66或IP68防护等级的接头。 - 应用信息: 适用于需要安全连接和耐化学腐蚀的应用场景。 - 封装信息: 10个/袋,海关编号为3926909987。
166-90099 价格&库存
很抱歉,暂时无法提供与“166-90099”相匹配的价格&库存,您可以联系我们找货
