166-90100
166-90100
    HELLERMAN(海尔曼太通)
    HELAGUARD-90DEGREENPTTHREAD
166-90100 数据手册
166-90100 Article Number: 166-90100 Description: HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, NPT Thread, 1.00" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90100 Type HG100-90-1000 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP66 Fitting, 90-Elbow, NPT Thread, 1.00" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.96" Length L (Metric) 75mm Bore Diameter (Imperial) 0.97" Bore Diameter (Metric) 24.5mm Clearance Hole Diameter (Imperial) 1.311" Clearance Hole Diameter (Metric) 33.3mm Euro (NW) Size 29mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.63" Thread Type NPT Trade Size 1" Product Dimensions generated on: 5/10/2017 166-90100 Product Dimensions Variant 90° Elbow Outside Diameter D (imperial) 2.04" Outside Diameter D (metric) 51mm Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 34mm Thread Length (metric) 16mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Listed (US) Yes UL Listed (US and Canada) Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90100 价格&库存
很抱歉,暂时无法提供与“166-90100”相匹配的价格&库存,您可以联系我们找货
