166-90113
166-90113
    HELLERMAN(海尔曼太通)
    HELAGUARD-90DEGREEIP68.50"
166-90113 数据手册
166-90113 Article Number: 166-90113 Description: HelaGuard Non-Metallic IP68 Fitting, 90-Elbow, NPT Thread, 0.50" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90113 Type HGL050-90-0500 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP68 Fitting, 90-Elbow, NPT Thread, 0.50" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.09" Length L (Metric) 53mm Bore Diameter (Imperial) 0.55" Bore Diameter (Metric) 14.0mm Clearance Hole Diameter (Imperial) 0.827" Clearance Hole Diameter (Metric) 21mm Euro (NW) Size 17mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.51" Thread Type NPT Trade Size 1/2 " Product Dimensions generated on: 5/10/2017 166-90113 Product Dimensions Variant 90° Elbow Outside Diameter D (imperial) 1.26" Outside Diameter D (metric) 32mm Nominal Diameter (Imperial) 1/2" Nominal Diameter (Metric) 21mm Thread Length (metric) 13mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90113 价格&库存
很抱歉,暂时无法提供与“166-90113”相匹配的价格&库存,您可以联系我们找货
