166-90176
166-90176
    HELLERMAN(海尔曼太通)
    HELAGUARD-T-CONNIP66FITTING
166-90176 数据手册
166-90176 Article Number: 166-90176 Description: HelaGuard Non-Metallic IP66 Fitting, T-Connector, 1.00" Dia, PA66, Black, 2/pkg Base Data Local Order Number 166-90176 Type HG100-T Color Black (BK) Features and benefits ‡Used to join conduits of same diameters and route to multiple directions. ‡Inspection lid facilitates cable pull through and eases installation. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡Vibration and shock tested to EN61373 Category 2. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description T- Connectors are used to join three same diameter corrugated conduits together, and redirect cables into multiple directions. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP66 Fitting, T-Connector, 1.00" Dia, PA66, Black, 2/pkg Length L (Imperial) 3.58" Length L (Metric) 91mm Bore Diameter (Imperial) 1.30" Bore Diameter (Metric) 33.0mm Euro (NW) Size 29mm Swivel Thread (Y/N) No Trade Size 1" Variant T-Connector Outside Diameter D (imperial) 5.12" Outside Diameter D (metric) 130mm Product Dimensions generated on: 5/10/2017 166-90176 Product Dimensions Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 34mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 2 Package Quantity (Metric) 2Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90176 价格&库存
很抱歉,暂时无法提供与“166-90176”相匹配的价格&库存,您可以联系我们找货
  • 50+685.5970450+88.80880
