166-90126
166-90126
    HELLERMAN(海尔曼太通)
    HELAGUARD-IP6545DEGREEELBOW
166-90126 数据手册
166-90126 Article Number: 166-90126 Description: HelaGuard Non-Metallic IP65 Fitting, 45-Elbow, NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90126 Type PSR075-45-0750 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Twist-on installation makes future access fast and easy. ‡Internal spigot design helps ease threading of fitting onto conduit. ‡All-around ³teeth´attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP65 rating for protection against wind, dirt and low pressure jets of water from all directions. Quantity Per bag Product Description Compression fittings feature a twist-on design for easy installation and future access. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Fits HelaGuard non-metallic conduits and tubing. Short Description HelaGuard Non-Metallic IP65 Fitting, 45-Elbow, NPT Thread, 0.75" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.76" Length L (Metric) 70mm Bore Diameter (Imperial) 0.75" Bore Diameter (Metric) 19.0mm Clearance Hole Diameter (Imperial) 1.039" Clearance Hole Diameter (Metric) 26.4mm Thread Length (Imperial) 0.59" Trade Size 3/4 " Outside Diameter D (imperial) 1.65" Outside Diameter D (metric) 42mm Nominal Diameter (Imperial) 3/4" Nominal Diameter (Metric) 25mm Thread Length (metric) 15mm Product Dimensions generated on: 5/10/2017 166-90126 Material and Specifications Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Operating Temperature -40°F to +248°F (-40°C to +120°C) ROHS Compliant Yes UL Recognized (US) Yes UL Recognized (US and Canada) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90126 价格&库存
很抱歉,暂时无法提供与“166-90126”相匹配的价格&库存,您可以联系我们找货
