166-90115
166-90115
    HELLERMAN(海尔曼太通)
    HELAGUARD-90DEGREEIP681.00"
166-90115 数据手册
166-90115 Article Number: 166-90115 Description: HelaGuard Non-Metallic IP68 Fitting, 90-Elbow, NPT Thread, 1.00" Dia, PA66, Black, 10/pkg Base Data Local Order Number 166-90115 Type HGL100-90-1000 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP68 Fitting, 90-Elbow, NPT Thread, 1.00" Dia, PA66, Black, 10/pkg Length L (Imperial) 2.96" Length L (Metric) 75mm Bore Diameter (Imperial) 0.97" Bore Diameter (Metric) 24.5mm Clearance Hole Diameter (Imperial) 1.311" Clearance Hole Diameter (Metric) 33.3mm Euro (NW) Size 29mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.63" Thread Type NPT Trade Size 1" Product Dimensions generated on: 5/10/2017 166-90115 Product Dimensions Variant 90° Elbow Outside Diameter D (imperial) 2.04" Outside Diameter D (metric) 51mm Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 34mm Thread Length (metric) 16mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Listed (US) Yes UL Listed (US and Canada) Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90115
PDF文档中的物料型号是166-90115,属于HellermannTyton品牌。
该产品是一种HelaGuard非金属IP68防水接头,具体型号为90度弯头,NPT螺纹,直径1英寸。
材料为PA66,颜色为黑色。
产品具有以下特性和优势:外螺纹提供安全的连接,快装式结构减少了安装时间和成本,无需将接头螺纹到导管上。
弯头具有光滑的内腔,便于电缆安装。
全方位的"牙齿"设计,牢固地附着在导管上,并提供高拉力。
耐用的尼龙材料对盐、油、弱酸和溶剂具有高抵抗力。
IP66接头为一体式结构,IP68接头则增加了导管密封,以增强对风、灰尘和水的防护。
产品尺寸包括长度2.96英寸(75mm),孔径0.97英寸(24.5mm)。
材料PA66,阻燃等级为UL94V2,无卤,符合RoHS标准,工作温度范围为-58°F至+275°F(-50°C至+135°C)。
产品包装为每袋10个。
166-90115 价格&库存
很抱歉,暂时无法提供与“166-90115”相匹配的价格&库存,您可以联系我们找货
