166-90109
166-90109
    HELLERMAN(海尔曼太通)
    HELAGUARD-45DEGREENPTELBOW
166-90109 数据手册
166-90109 Article Number: 166-90109 Description: HelaGuard Non-Metallic IP68 Fitting, 45-Elbow, NPT Thread, 0.50" Dia, Black, 10/pkg Base Data Local Order Number 166-90109 Type HGL050-45-0500 Color Black (BK) Features and benefits ‡External NPT thread provides a secure connection. ‡Snap-on construction reduces installation time and costs by eliminating the need to thread fittings onto conduits. ‡Elbow features a smooth, swept bore to ease cable installation. ‡All-around "teeth" attach firmly to conduit and deliver a high extraction force. ‡Durable nylon material has high resistance to salts, oils, weak acids and solvents. ‡IP66 fitting has one-piece construction. ‡IP68 fitting has additional conduit seal for increased protection against wind, dirt and water. Quantity Per bag Product Description Elbow fitting features a snap-on design that provides a quick, secure connection. Constructed of a very durable nylon material with a high resistance to salts, oils, weak acids and solvents. Designed for easy removal with a small screwdriver. Choose from IP66 or IP68 ingress protection rated fittings. Short Description HelaGuard Non-Metallic IP68 Fitting, 45-Elbow, NPT Thread, 0.50" Dia, Black, 10/pkg Length L (Imperial) 2.40" Length L (Metric) 61mm Bore Diameter (Imperial) 0.55" Bore Diameter (Metric) 14.0mm Clearance Hole Diameter (Imperial) 0.827" Clearance Hole Diameter (Metric) 21mm Euro (NW) Size 17mm Swivel Thread (Y/N) No Thread Length (Imperial) 0.51" Thread Type NPT Trade Size 1/2 " Product Dimensions generated on: 5/10/2017 166-90109 Product Dimensions Variant 45° Elbow Outside Diameter D (imperial) 1.26" Outside Diameter D (metric) 32mm Nominal Diameter (Imperial) 1/2" Nominal Diameter (Metric) 21mm Thread Length (metric) 13mm Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -58°F to +275°F (-50°C to +135°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10Pieces Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90109
1. 物料型号:166-90109 2. 器件简介:HelaGuard非金属IP68接头,45度弯头,NPT螺纹,直径0.50英寸,黑色,10个/包。 3. 引脚分配:未提供具体引脚分配信息,因为这是一个接头而非电子元件。 4. 参数特性: - 材质:Polyamide 6.6 (PA66) - 卤素含量:无卤素 - 阻燃等级:UL 94V2 - 工作温度范围:-58°F至+275°F (-50°C至+135°C) - ROHS合规性:是 - UL认证:美国和加拿大认可 5. 功能详解: - 外部NPT螺纹提供安全连接。 - 快装结构减少了安装时间和成本,无需将接头螺纹到导管上。 - 弯头具有平滑的内腔,便于电缆安装。 - 全方位“牙齿”结构牢固地附着在导管上,提供高提取力。 - 耐用的尼龙材料具有高抗盐、油、弱酸和溶剂性。 - IP66接头为一体式构造。 - IP68接头有额外的导管密封,增强了对风、尘和水的防护。 6. 应用信息:设计用于IP66或IP68防护等级的接头,易于拆卸,只需小螺丝刀。 7. 封装信息: - 产品尺寸:长度2.40英寸(61mm),内径0.55英寸(14.0mm),开孔直径0.827英寸(21mm),欧标尺寸17mm。 - 螺纹长度:0.51英寸,螺纹类型NPT,贸易尺寸1/2英寸。 - 包装数量:10个/包。
166-90109 价格&库存
很抱歉,暂时无法提供与“166-90109”相匹配的价格&库存,您可以联系我们找货
