PTR016V0075-BK1
PTR016V0075-BK1
    EATON(伊顿)
    径向
    PTC RESETTABLE RADIAL 16V 0.75A
PTR016V0075-BK1 数据手册
HALOGEN 16 Volt DC Radial Leaded, Resettable PPTC Devices Pb HF FREE PolyTron™ PTR016V Series Agency Information • cURus: Recognized Card: File E343021 (Ihold 3A-15A) • TUV File: J 50194729 Part Number System/Ordering PT Radial Leaded Device Description • • • • • • • • R 016V 0075 -TR PolyTron™ Resettable Fuse Series Radial Leaded Fuse Maximum Voltage Current Holding (Ihold) Tape and Reel Packaging and Lead Type Code TR - Straight Leads, TR1 - Kinked Leads • 0.75 to 1.85 amps - 3000 fuses per reel • 2.5 to 4 amps - 2500 fuses per reel • 5 to 7 amps - 1500 fuses per reel • 8 to 15 amps - 1000 fuse per reel Resettable radial leaded thru-hole fuse Maximum 16 volts Current ratings from 0.75 to 15 amps Fast time-to-trip Low resistance Halogen free Lead free RoHS compliant Applications • Medical equipment • Telecommunications • White goods • Computers and peripherals Specifications Catalog Number PTR016V0075 PTR016V0090 PTR016V0110 PTR016V0120 PTR016V0135 PTR016V0155 PTR016V0160 PTR016V0185 PTR016V0250 PTR016V0300 PTR016V0400 PTR016V0500 PTR016V0600 PTR016V0700 PTR016V0800 PTR016V0900 PTR016V1000 PTR016V1100 PTR016V1200 PTR016V1300 PTR016V1400 PTR016V1500 Notes: 0111 Vmax (Vdc) 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 Imax (Amps) 40 40 40 40 40 40 40 40 40 100 100 100 100 100 100 100 100 100 100 100 100 100 Ihold @23°C (Amps) 0.75 0.90 1.10 1.20 1.35 1.55 1.60 1.85 2.50 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 Itrip @23°C (Amps) 1.50 1.80 2.20 2.40 2.70 3.10 3.20 3.70 5.00 5.10 6.80 8.50 10.20 11.90 13.60 15.30 17.00 18.70 20.40 22.10 23.80 25.50 Pd Typ. (W) 0.30 0.60 0.70 0.60 0.80 0.70 0.90 1.00 1.20 2.30 2.40 2.60 2.80 3.00 3.00 3.30 3.60 3.70 4.20 4.60 4.60 4.60 Time to Trip (Max.) (Amps) (Sec) 8.00 0.40 8.00 1.20 8.00 2.30 8.00 0.50 8.00 4.50 8.00 0.60 8.00 9.00 8.00 10.00 8.00 40.00 15.00 1.00 20.00 1.70 25.00 2.00 30.00 3.30 35.00 3.50 40.00 5.00 45.00 5.50 50.00 6.00 55.00 7.00 60.00 7.50 65.00 8.50 70.00 9.00 75.00 10.00 Resistance (Ω) Agency Initial (Ri) Post Trip (R1) Information Min. Max. Max. cURus TUV 0.110 0.175 0.230 X 0.070 0.120 0.180 X 0.050 0.095 0.140 X 0.065 0.0975 0.140 X 0.040 0.074 0.120 X 0.043 0.0705 0.100 X 0.030 0.061 0.110 X 0.030 0.051 0.090 X 0.020 0.036 0.070 X 0.038 0.065 0.098 X X 0.021 0.038 0.060 X X 0.010 0.023 0.034 X X 0.006 0.018 0.028 X X 0.006 0.013 0.020 X X 0.005 0.011 0.018 X X 0.005 0.009 0.014 X X 0.004 0.007 0.010 X X 0.003 0.006 0.009 X X 0.003 0.006 0.009 X X 0.002 0.006 0.008 X X 0.002 0.005 0.007 X X 0.002 0.005 0.007 X X Ihold – Hold current: Maximum current device will pass without interruption in 23°C still air. Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in 23°C still air. Vmax: Maximum continuous voltage device can withstand without damage at rated current. Imax: Maximum fault current device can withstand without damage at rated voltage. Pd: Power dissipated from device when in the tripped state in 23°C still air. Ri (min.): Minimum resistance of device as supplied at 23°C unless otherwise specified. Ri (max.): Maximum resistance of device as supplied at 23°C unless otherwise specified. R1(max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at 23°C unless otherwise specified. BU-SB11018 Page 1 of 4 Data Sheet 4399 Dimensions - mm Part Number PTR016V0075 PTR016V0090 PTR016V0110 PTR016V0120 PTR016V0135 PTR016V0155 PTR016V0160 PTR016V0185 PTR016V0250 PTR016V0300 PTR016V0400 PTR016V0500 PTR016V0600 PTR016V0700 PTR016V0800 PTR016V0900 PTR016V1000 PTR016V1100 PTR016V1200 PTR016V1300 PTR016V1400 PTR016V1500 A Max. 7.0 7.4 7.4 7.0 8.9 6.9 8.9 10.2 11.4 7.1 8.9 10.4 10.7 11.2 12.7 14.0 16.5 17.5 17.5 21.6 23.5 25.1 B Max Lead Type Straight Kink (-TR) (-TR1) 11.4 12.2 12.2 14.2 14.2 11.7 13.5 13.5 11.7 15.2 15.2 15.7 15.7 18.3 20.5 11.0 14.0 12.8 14.8 14.3 16.0 17.1 19.0 19.7 22.0 20.9 23.0 21.9 24.0 25.2 28.0 26.0 29.0 28.0 31.0 29.2 32.0 27.9 30.0 29.0 32.0 D Min. 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 C 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 10.0±0.8 10.0±0.8 10.0±0.8 10.0±0.8 E Max. 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 F 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 1.0±0.02 1.0±0.02 1.0±0.02 1.0±0.02 Figure/ Lead Style Straight Kink TR TR1 3 2 1 2 1 3 2 1 3 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 Style 1 Style 2 Style 3 Time-to-Trip Curves at 23°C - 0.75-2.5A B 1000 D E G H I A:PTR016V0075 B:PTR016V0090 100 A c C :PTR016V0110 F TIM E IN S E C O N D S 10 D :PTR016V0120 E:PTR016V0135 1 F :PTR016V0155 G :PTR016V0160 0.1 H :PTR016V0185 I:PTR016V0250 0.01 0.001 1 10 100 Fa u lt Cu rre n t (A ) 0111 BU-SB11018 Page 2 of 4 Data Sheet 4399 Time-to-Trip Curves at 23°C - 3.0-15A J 1000 K L M N O P Q R S T U V J :PTR016V0300 K:PTR016V0400 100 L:PTR016V0500 M :PTR016V0600 N :PTR016V0700 10 TIM E IN S E CO ND S O :PTR016V0800 P:PTR016V0900 Q :PTR016V1000 1 R :PTR016V1100 S:PTR016V1200 0 .1 T :PTR016V1300 U :PTR016V1400 V:PTR016V1500 0 .0 1 0 .0 0 1 1 10 100 F ault Current (A ) Thermal Derating Curve P erc entage of D erated C urrent 200.0 180.0 160.0 140.0 120.0 100.0 80.0 60.0 40.0 20.0 0.0 -40 -20 0 20 40 Tem perature (°C) Recommended Wave Solder Profile P re h e a tin g So ld e rin g Co o lin g T e m p e ra ture No te 2 Solvent Resistance Humidity Age Test No te 3 130 ± 200°C No te 1 T am b Notes: t
PTR016V0075-BK1 价格&库存
很抱歉,暂时无法提供与“PTR016V0075-BK1”相匹配的价格&库存,您可以联系我们找货
