SMBJ9.0CATR
SMBJ9.0CATR
    SMCDIODESOLUTIONS(桑德斯)
    SMB(DO-214AA)
    TVS DIODE 9VWM 15.4VC SMB
SMBJ9.0CATR 数据手册
SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C SMBJ SERIES SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features:            Glass Passivated Die Construction 600W Peak Pulse Power Dissipation 5.0V- 400V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O “-A” is an AEC-Q101 qualified device This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data:     Case: JEDEC DO-214AA Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD 750, Method 2026 Polarity: Cathode Band or Cathode Notch Weight:0.093 grams(approx.) Mechanical Dimensions:In Inches(mm) SMB/DO-214AA Dim. A B C D E F G H Min. Max. Min. Max. 3.30 3.94 0.130 0.155 4.06 4.70 0.160 0.185 1.80 2.20 0.071 0.087 0.152 0.305 0.006 0.012 4.80 5.59 0.189 0.220 2.10 2.60 0.083 0.102 0.051 0.203 0.002 0.008 0.76 1.52 0.030 0.060 In mm In inch SMB  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C Marking Diagram: Where XXXXX is YYWWL KD/AD YY WW L SMBJ5.0 = Part Name = Year = Week = Lot Number SMBJ5.0C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device Package SMB (Pb-Free) SMBJ SERIES Shipping 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C by 10x1000μs Waveform (Fig.1)(Note 1), (Note 2) Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 2),(Note 3) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 600 W IFSM 100 A TJ,TSTG -55 to 150 °C Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5.0mm²(0.013mm thick)land areas. 3. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4pulses per minute maximum.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Technical Data Data Sheet N0193, Rev. C Automotive Qualified  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C UNI-DIRECTIONAL 600 WATT SURFACE MOUNT TVS UNIDIRECTIONAL PART NO. DEVICE MARKING CODE REVERSE STAND-OFF VOLTAGE VRWM (V) BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURREN T IT(MA) MAXMUM CLAMPING VOLTAGE @IPP VC(V) PEAK PULSE CURRENT IPP(A) REVERSE LEAKAGE @VRWM IR(uA) SMBJ5.0 KD 5.00 6.40 7.82 10 9.6 62.5 800 SMBJ5.0A KE 5.00 6.40 7.07 10 9.2 65.2 800 SMBJ6.0 KF 6.00 6.67 8.15 10 11.4 52.6 800 SMBJ6.0A KG 6.00 6.67 7.37 10 10.3 58.3 800 SMBJ6.5 KH 6.50 7.22 8.82 10 12.3 48.7 500 SMBJ6.5A KK 6.50 7.22 7.98 10 11.2 53.6 500 SMBJ7.0 KL 7.00 7.78 9.51 10 13.3 45.1 200 SMBJ7.0A KM 7.00 7.78 8.60 10 12.0 50.0 200 SMBJ7.5 KN 7.50 8.33 10.18 1 14.3 42.0 100 SMBJ7.5A KP 7.50 8.33 9.21 1 12.9 46.5 100 SMBJ8.0 KQ 8.00 8.99 10.99 1 15.0 40.0 50 SMBJ8.0A KR 8.00 8.99 9.94 1 13.6 44.1 50 SMBJ8.5 KS 8.5 9.44 11.54 1 15.9 37.7 10 SMBJ8.5A KT 8.5 9.44 1.43 1 14.4 41.7 10 SMBJ9.0 KU 9.0 10.00 12.22 1 16.9 35.5 5 SMBJ9.0A KV 9.0 10.00 11.05 1 15.4 39.0 5 SMBJ10 KW 10 11.10 13.57 1 18.8 31.9 5 SMBJ10A KX 10 11.10 12.27 1 17.0 35.3 5 SMBJ11 KY 11 12.20 14.91 1 20.1 29.9 5 SMBJ11A KZ 11 12.20 13.48 1 18.2 33.0 5 SMBJ12 LD 12 13.30 16.26 1 22.0 27.3 5 SMBJ12A LE 12 13.30 14.70 1 19.9 30.2 5 SMBJ13 LF 13 14.40 17.60 1 23.8 25.2 5 SMBJ13A LG 13 14.40 15.92 1 21.5 27.9 5 SMBJ14 LH 14 15.60 19.07 1 25.8 23.3 5 SMBJ14A LK 14 15.60 17.24 1 23.2 25.8 5 SMBJ15 LL 15 16.70 20.41 1 26.9 22.3 5 SMBJ15A LM 15 16.70 18.46 1 24.4 24.0 5 SMBJ16 LN 16 17.80 21.76 1 28.8 20.8 5 SMBJ16A LP 16 17.80 19.67 1 26.0 23.1 5 SMBJ17 LQ 17 18.90 23.10 1 30.5 19.7 5 SMBJ17A LR 17 18.90 20.89 1 27.6 21.7 5 SMBJ18 LS 18 20.00 24.44 1 32.2 18.6 5 SMBJ18A LT 18 20.00 22.11 1 29.2 20.5 5 SMBJ20 LU 20 22.20 27.13 1 35.8 16.7 5 SMBJ20A LV 20 22.20 24.54 1 32.4 18.5 5 SMBJ22 LW 22 24.40 29.82 1 39.4 15.2 5 SMBJ22A LX 22 24.40 26.97 1 35.5 16.9 5 SMBJ24 LY 24 26.70 32.63 1 43.0 14.0 5 SMBJ24A LZ 24 26.70 29.51 1 38.9 15.4 5 SMBJ26 MD 26 28.90 35.32 1 46.6 12.4 5 SMBJ26A ME 26 28.90 31.94 1 42.1 14.2 5 SMBJ28 MF 28 31.10 38.01 1 50.0 12.0 5 SMBJ28A MG 28 31.10 34.37 1 45.4 13.2 5 SMBJ30 MH 30 33.30 40.70 1 53.5 11.2 5 SMBJ30A MK 30 33.30 36.81 1 48.4 12.4 5 SMBJ33 ML 33 36.70 44.86 1 59.0 10.2 5 SMBJ33A MM 33 36.70 40.56 1 53.3 13.2 5 SMBJ36 MN 36 40.00 48.89 1 64.3 9.3 5 SMBJ36A MP 36 40.00 44.21 1 58..1 10.3 5  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C UNIDIRECTIONAL PART NO. DEVICE MARKING CODE REVERSE STAND-OFF VOLTAGE VRWM (V) BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURREN T IT(MA) MAXMUM CLAMPING VOLTAGE @IPP VC(V) PEAK PULSE CURRENT IPP(A) REVERSE LEAKAGE @VRWM IR(uA) SMBJ40 MQ 40 44.40 54.27 1 71.4 8.4 5 SMBJ40A MR 40 44.40 49.07 1 64.5 9.3 5 SMBJ43 MS 43 47.80 58.42 1 76.7 7.8 5 SMBJ43A MT 43 47.80 52.83 1 69.4 8.6 5 SMBJ45 MU 45 50.00 61.11 1 80.3 7.5 5 SMBJ45A MV 45 50.00 55.26 1 72.7 8.3 5 SMBJ48 MW 48 53.30 65.14 1 85.5 7.0 5 SMBJ48A MX 48 53.30 58.91 1 77.4 7.7 5 SMBJ51 MY 51 56.70 69.30 1 91.1 6.6 5 SMBJ51A MZ 51 56.70 62.67 1 82.4 7.3 5 SMBJ54 ND 54 60.00 73.33 1 96.3 6.2 5 SMBJ54A NE 54 60.00 66.32 1 87.1 6.9 5 SMBJ58 NF 58 64.40 78.71 1 103.0 5.8 5 SMBJ58A NG 58 64.40 71.18 1 93.6 6.4 5 SMBJ60 NH 60 66.70 81.52 1 107.0 5.6 5 SMBJ60A NK 60 66.70 73.72 1 96.8 6.2 5 SMBJ64 NL 64 71.10 86.90 1 114.0 5.3 5 SMBJ64A NM 64 71.10 78.58 1 103.0 5.8 5 SMBJ70 NN 70 77.80 95.09 1 125.0 4.8 5 SMBJ70A NP 70 77.80 85.99 1 113.0 5.3 5 SMBJ75 NQ 75 83.30 101.81 1 134.0 4.5 5 SMBJ75A NR 75 83.30 92.07 1 121.0 4.9 5 SMBJ78 NS 78 86.70 105.97 1 139.0 4.3 5 SMBJ78A NT 78 86.70 95.83 1 126.0 4.7 5 SMBJ85 NU 85 94.40 115.38 1 151.0 3.9 5 SMBJ85A NV 85 94.40 104.34 1 137.0 4.4 5 SMBJ90 NW 90 100.00 122.22 1 160.0 3.8 5 SMBJ90A NX 90 10.00 110.53 1 146.0 4.1 5 SMBJ100 NY 100 111.00 135.67 1 179.0 3.4 5 SMBJ100A NZ 100 111.00 122.68 1 162.0 3.7 5 SMBJ110 PD 110 122.00 149.11 1 196.0 3.0 5 SMBJ110A PE 110 122.00 134.84 1 177.0 3.4 5 SMBJ120 PF 120 133.00 162.56 1 214.0 2.8 5 SMBJ120A PG 120 133.00 147.00 1 193.0 3.1 5 SMBJ130 PH 130 144.00 176.00 1 231.0 2.6 5 SMBJ130A PK 130 144.00 159.16 1 209.0 2.9 5 SMBJ150 PL 150 167.00 204.11 1 269.0 2.2 5 SMBJ150A PM 150 167.00 184.58 1 243.0 2.5 5 SMBJ160 PN 160 178.00 217.56 1 287.0 2.1 5 SMBJ160A PP 160 178.00 196.74 1 259.0 2.3 5 SMBJ170 PQ 170 189.00 231.00 1 304.0 2.0 5 SMBJ170A PR 170 189.00 208.89 1 275.0 2.2 5 SMBJ180A PT 180 201 222 1 292 2.1 1 SMBJ200A PV 200 224 247 1 324 1.9 1 SMBJ220A PX 220 246 272 1 356 1.7 1 SMBJ250A PZ 250 279 309 1 405 1.5 1 SMBJ300A QE 300 335 371 1 486 1.3 1 SMBJ350A QG 350 391 432 1 567 1.1 1 SMBJ400A QK 400 447 494 1 648 0.9 1 SMBJ440A QM 440 492 543 1 713 0.9 1 “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices “-A” Suffix is an AEC-Q101 qualified device  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C BI-DIRECTIONAL 600 WATT SURFACE MOUNT TVS DEVICE MARKING CODE REVERSE STAND-OFF VOLTAGE VRWM (V) BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURRE NT IT(MA) MAXMUM CLAMPING VOLTAGE @IPP VC(V) PEAK PULSE CURRENT IPP(A) REVERSE LEAKAGE @VRWM IR(uA) SMBJ5.0C AD 5.00 6.40 7.82 10 9.6 62.5 1600 SMBJ5.0CA AE 5.00 6.40 7.07 10 9.2 65.2 1600 SMBJ6.0C AF 6.00 6.67 8.15 10 11.4 52.6 1600 SMBJ6.0CA AG 6.00 6.67 7.37 10 10.3 58.3 1600 SMBJ6.5C AH 6.50 7.22 8.82 10 12.3 48.7 1000 SMBJ6.5CA AK 6.50 7.22 7.98 10 11.2 53.6 1000 SMBJ7.0C AL 7.00 7.78 9.51 10 13.3 45.1 400 SMBJ7.0CA AM 7.00 7.78 8.60 10 12.0 50.0 400 SMBJ7.5C AN 7.50 8.33 10.18 1 14.3 42.0 200 SMBJ7.5CA AP 7.50 8.33 9.21 1 12.9 46.5 200 SMBJ8.0C AQ 8.00 8.99 10.99 1 15.0 40.0 100 SMBJ8.0CA AR 8.00 8.99 9.94 1 13.6 44.1 100 SMBJ8.5C AS 8.5 9.44 11.54 1 15.9 37.7 20 SMBJ8.5CA AT 8.5 9.44 11.43 1 14.4 41.7 20 SMBJ9.0C AU 9.0 10.00 12.22 1 16.9 35.5 10 SMBJ9.0CA AV 9.0 10.00 11.05 1 15.4 39.0 10 SMBJ10C AW 10 11.10 13.57 1 18.8 31.9 5 SMBJ10CA AX 10 11.10 12.27 1 17.0 35.3 5 SMBJ11C AY 11 12.20 14.91 1 20.1 29.9 5 SMBJ11CA AZ 11 12.20 13.48 1 18.2 33.0 5 SMBJ12C BD 12 13.30 16.26 1 22.0 27.3 5 SMBJ12CA BE 12 13.30 14.70 1 19.9 30.2 5 SMBJ13C BF 13 14.40 17.60 1 23.8 25.2 5 SMBJ13CA BG 13 14.40 15.92 1 21.5 27.9 5 BIDIRECTIONA L PART NO. SMBJ14C BH 14 15.60 19.07 1 25.8 23.3 5 SMBJ14CA BK 14 15.60 17.24 1 23.2 25.8 5 SMBJ15C BL 15 16.70 20.41 1 26.9 22.3 5 SMBJ15CA BM 15 16.70 18.46 1 24.4 24.0 5 SMBJ16C BN 16 17.80 21.76 1 28.8 20.8 5 SMBJ16CA BP 16 17.80 19.67 1 26.0 23.1 5 SMBJ17C BQ 17 18.90 23.10 1 30.5 19.7 5 SMBJ17CA BR 17 18.90 20.89 1 27.6 21.7 5 SMBJ18C BS 18 20.00 24.44 1 32.2 18.6 5 SMBJ18CA BT 18 20.00 22.11 1 29.2 20.5 5 SMBJ20C BU 20 22.20 27.13 1 35.8 16.7 5 SMBJ20CA BV 20 22.20 24.54 1 32.4 18.5 5 SMBJ22C BW 22 24.40 29.82 1 39.4 15.2 5 SMBJ22CA BX 22 24.40 26.97 1 35.5 16.9 5 SMBJ24C BY 24 26.70 32.63 1 43.0 14.0 5 SMBJ24CA BZ 24 26.70 29.51 1 38.9 15.4 5 SMBJ26C CD 26 28.90 35.32 1 46.6 12.4 5 SMBJ26CA CE 26 28.90 31.94 1 42.1 14.2 5 SMBJ28C CF 28 31.10 38.01 1 50.0 12.0 5 SMBJ28CA CG 28 31.10 34.37 1 45.4 13.2 5 SMBJ30C CH 30 33.30 40.70 1 53.5 11.2 5 SMBJ30CA CK 30 33.30 36.81 1 48.4 12.4 5 SMBJ33C CL 33 36.70 44.86 1 59.0 10.2 5 SMBJ33CA CM 33 36.70 40.56 1 53.3 13.2 5 SMBJ36C CN 36 40.00 48.89 1 64.3 9.3 5 SMBJ36CA CP 36 40.00 44.21 1 58..1 10.3 5  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Automotive Qualified Technical Data Data Sheet N0193, Rev. C BIDIRECTIONA L PART NO. DEVICE MARKING CODE REVERSE STAND-OFF VOLTAGE VRWM (V) BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT TEST CURRE NT IT(MA) MAXMUM CLAMPING VOLTAGE @IPP VC(V) PEAK PULSE CURRENT IPP(A) REVERSE LEAKAGE @VRWM IR(uA) SMBJ40C CQ 40 44.40 54.27 1 71.4 8.4 5 SMBJ40CA CR 40 44.40 49.07 1 64.5 9.3 5 SMBJ43C CS 43 47.80 58.42 1 76.7 7.8 5 SMBJ43CA CT 43 47.80 52.83 1 69.4 8.6 5 SMBJ45C CU 45 50.00 61.11 1 80.3 7.5 5 SMBJ45CA CV 45 50.00 55.26 1 72.7 8.3 5 SMBJ48C CW 48 53.30 65.14 1 85.5 7.0 5 SMBJ48CA CX 48 53.30 58.91 1 77.4 7.7 5 SMBJ51C CY 51 56.70 69.30 1 91.1 6.6 5 SMBJ51CA CZ 51 56.70 62.67 1 82.4 7.3 5 SMBJ54C DD 54 60.00 73.33 1 96.3 6.2 5 SMBJ54CA DE 54 60.00 66.32 1 87.1 6.9 5 SMBJ58C DF 58 64.40 78.71 1 103.0 5.8 5 SMBJ58CA DG 58 64.40 71.18 1 93.6 6.4 5 SMBJ60C DH 60 66.70 81.52 1 107.0 5.6 5 SMBJ60CA DK 60 66.70 73.72 1 96.8 6.2 5 SMBJ64C DL 64 71.10 86.90 1 114.0 5.3 5 SMBJ64CA DM 64 71.10 78.58 1 103.0 5.8 5 SMBJ70C DN 70 77.80 95.09 1 125.0 4.8 5 SMBJ70CA DP 70 77.80 85.99 1 113.0 5.3 5 SMBJ75C DQ 75 83.30 101.81 1 134.0 4.5 5 SMBJ75CA DR 75 83.30 92.07 1 121.0 4.9 5 SMBJ78C DS 78 86.70 105.97 1 139.0 4.3 5 SMBJ78CA DT 78 86.70 95.83 1 126.0 4.7 5 SMBJ85C DU 85 94.40 115.38 1 151.0 3.9 5 SMBJ85CA DV 85 94.40 104.34 1 137.0 4.4 5 SMBJ90C DW 90 100.00 122.22 1 160.0 3.8 5 SMBJ90CA DX 90 10.00 110.53 1 146.0 4.1 5 SMBJ100C DY 100 111.00 135.67 1 179.0 3.4 5 SMBJ100CA DZ 100 111.00 122.68 1 162.0 3.7 5 SMBJ110C ED 110 122.00 149.11 1 196.0 3.0 5 SMBJ110CA EE 110 122.00 134.84 1 177.0 3.4 5 SMBJ120C EF 120 133.00 162.56 1 214.0 2.8 5 SMBJ120CA EG 120 133.00 147.00 1 193.0 3.1 5 SMBJ130C EH 130 144.00 176.00 1 231.0 2.6 5 SMBJ130CA EK 130 144.00 159.16 1 209.0 2.9 5 SMBJ150C EL 150 167.00 204.11 1 269.0 2.2 5 SMBJ150CA EM 150 167.00 184.58 1 243.0 2.5 5 SMBJ160C EN 160 178.00 217.56 1 287.0 2.1 5 SMBJ160CA EP 160 178.00 196.74 1 259.0 2.3 5 SMBJ170C EQ 170 189.00 231.00 1 304.0 2.0 5 SMBJ170CA ER 170 189.00 208.89 1 275.0 2.2 5 SMBJ180CA ET 180 201 222 1 292 2.1 1 SMBJ200CA EV 200 224 247 1 324 1.9 1 SMBJ220CA EX 220 246 272 1 356 1.7 1 SMBJ250CA EZ 250 279 309 1 405 1.5 1 SMBJ300CA FE 300 335 371 1 486 1.3 1 SMBJ350CA FG 350 391 432 1 567 1.1 1 SMBJ400CA FK 400 447 494 1 648 0.9 1 SMBJ440CA FM 440 492 543 1 713 0.9 1 “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices “-A” Suffix is an AEC-Q101 qualified device  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMBJ SERIES Technical Data Data Sheet N0193, Rev. C Automotive Qualified DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SMBJ9.0CATR
物料型号:SMBJ系列
器件简介:SMBJ系列是表面安装瞬态电压抑制器(Transient Voltage Suppressor, TVS),用于汽车合格认证,具有玻璃钝化二极管结构,能够承受600W的峰值脉冲功率耗散。
引脚分配:器件采用JEDEC DO-214AA低矮塑料封装,具有可焊接的端子,符合MIL-STD 750标准。
参数特性: - 工作和存储温度范围:-55°C至+150°C - 峰值脉冲功率耗散:600W - 峰值正向浪涌电流:100A(8.3ms单半正弦波) - 反向漏电流:在VRWM条件下,从800uA到3.9uA不等,具体取决于型号
功能详解: - 提供单向和双向版本 - 具有优异的钳位能力 - 快速响应时间 - 塑料外壳材料具有UL 94V-0可燃性等级分类 - “-A”后缀表示符合AEC-Q101标准 - 所有SMC部件都可以追溯到晶圆批次
应用信息:适用于汽车电子和其他需要瞬态电压保护的应用。
封装信息:JEDEC DO-214AA低矮塑料封装,3000pcs/卷的包装方式。
SMBJ9.0CATR 价格&库存
很抱歉,暂时无法提供与“SMBJ9.0CATR”相匹配的价格&库存,您可以联系我们找货
