P6KE SERIES
Technical Data
Data Sheet N0157, Rev. B
Green Products
P6KE SERIES
TRANSIENT VOLTAGE SUPPRESSOR
Features:
Glass Passivated Die Construction
600W Peak Pulse Power Dissipation
6.8V- 440V Standoff Voltage
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability Classification Rating 94V-O
This is a Pb − Free Device
All SMC Parts are Traceable to the Wafer Lot
Additional testing can be offered upon request
Mechanical Data:
Case: JEDEC DO-15 Low Profile Molded Plastic
Terminals: Solder Plated , Solderable per MIL-STD-202, Method 208
Polarity: Cathode Band or Cathode Notch
Weight:0.41 grams(approx.)
Mechanical Dimensions:In Inches (mm)
DO-15
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
P6KE SERIES
Technical Data
Green Products
Marking Diagram
P6KE6.8/P6KE6.8C = Part Name
P6KE6.8
P6KE6.8C
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information
Device
Package
DO-15
(Pb-Free)
P6KE SERIES
Shipping
3000pcs / tape
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Parameter
Peak Pulse Power Dissipation at
TA=25°C (Fig.1)(Note 1, 2, 5)
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave Fig.6 (Note 3)
Peak Pulse Current on 10x1000μs
Waveform(Fig.3)(Note 1)
Steady State Power Dissipation( Note 2, 4)
Operating Junction and Storage
Temperature Range
Symbol
Value
Unit
PPPM
600
W
IFSM
100
A
IPPM
See Table 1
A
PM(AV)
5.0
W
TJ,TSTG
-55 to + 175
°C
Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 40mm² copper pad.
3. 8.3ms Single Half Sine Wave duty cycle = 4 pulses per minutes maximum
4. Lead temperature at 75°C= TL
3. Peak pulse power waveform is 10/1000μs.
P6KE SERIES
Technical Data
Green Products
P6KE SERIES
Technical Data
“C” Suffix Designates Bi-directional Devices
“A” Suffix Designates 5% Tolerance Devices
No Suffix Designates 10% Tolerance Devices
Green Products
P6KE SERIES
Technical Data
Green Products
P6KE SERIES
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“P6KE120CATA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65718
- 200+0.25434
- 500+0.24549
- 1000+0.24106
