SMDA03C
THRU
SMDA24C
Green Products
Technical Data
Data Sheet N0297, Rev. A
MARKING DIAGRAM
Where XXXXX is YYWWL
SMDA03C
S
YY
WW
L
= Part Name
=S
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
SMDA03C
THRU
SMDA24C
Green Products
Technical Data
Circuit Diagram
The SMDAxxC series of devices are designed to protect up to
four data lines. The devices are connected as follows:
✔ The SMDAxxC are bidirectional devices and are designed for
use on line where the normal operating voltage is above
ground. Pins 1, 2, 3, and 4 are connected to the protected
lines. Pins 5, 6, 7, and 8 are connected to ground. Since the
device is electrically symmetrical, these connections may be
reversed. The ground connections should be made directly
to the ground plane for best results. The path length is kept
as short as possible to reduce the effects of parasitic
inductance in the board traces.
Ordering Information:
Device
SMDA03C THRU SMDA24C
Package
Shipping
SO-8 (Pb-Free)
2500pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
SMDA03C
THRU
SMDA24C
Technical Data
Green Products
SMDA03C
THRU
SMDA24C
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SMDA03CTR”相匹配的价格&库存,您可以联系我们找货
