SMDB05LCCTR
SMDB05LCCTR
    SMCDIODESOLUTIONS(桑德斯)
    SOIC8_150MIL
    TVS DIODE 5VWM 9.8VC 8SO
SMDB05LCCTR 数据手册
SMDB03LCC THRU SMDB24LCC Green Products Technical Data Data Sheet N0427, Rev. B MARKING DIAGRAM Where XXXXX is YYWWL SMDB03LCC S YY WW L = Part Name =S = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMDB03LCC THRU SMDB24LCC Green Products Technical Data Data Sheet N0427, Rev. B PACKAGE OUTLINES & DEMENSIONS MILLMETER SYMBOL MIN. TYP. MAX. A - - 1.75 A1 0.10 - 0.225 A2 1.30 1.40 1.50 A3 0.60 0.65 0.70 b 0.39 - 0.48 c 0.21 - 0.26 D 4.70 4.90 5.10 E 3.70 3.90 4.10 E1 5.80 6.00 6.20 e 1.27BSC h 0.25 - 0.50 L 0.50 - 0.80 L1 Θ1 1.05BSC 0 SO-8 Circuit Diagram Ideal for Ethernet applications, SMDBxxLCC Series provides up to four (4) lines of protection in a commonmode configuration. Circuit connectivity is as follows: ✔ TPIN is connected to Pin 5. ✔ TPIP is connected to Pin 6. ✔ TPON is connected to Pin 1. ✔ TPOP is connected to Pin 2. ✔ Pins 3, 4, 7 & 8 are connected to ground. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • - 8° SMDB03LCC THRU SMDB24LCC Green Products Technical Data Data Sheet N0427, Rev. B Ordering Information: Device SMDB03LCC THRU SMDB24LCC Package Shipping SO-8 (Pb-Free) 2500pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMDB03LCC THRU SMDB24LCC Green Products Technical Data Data Sheet N0427, Rev. B Fig.1- Peak Pulse vs. Pulse Time (μs) Fig.2- Pulse Waveform (μs) CLAMPING VOLTAGE(V) 15 12 9 SMDB05LCC 6 3 0 0 5 10 15 20 25 30 35 40 PEAK PULSE CURRENT(A) Fig.3- Power Derating Curve Fig.4- Clamping Voltage vs. Peak Pulse Current • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMDB03LCC THRU SMDB24LCC Technical Data Data Sheet N0427, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
SMDB05LCCTR
物料型号:SMDB03LCC至SMDB24LCC
器件简介:该系列TVS阵列设计用于提供双向保护,防止电压瞬变引起的敏感电子设备损坏,如静电放电(ESD)、电快速瞬变(EFT)、雷击等。
该器件可用于保护四条双向线路的组合。
引脚分配:SO-8表面贴装封装,引脚编号如下: - 引脚1:TPON - 引脚2:TPOP - 引脚3、4、7和8:接地 - 引脚5:TPIN - 引脚6:TPIP
参数特性: - 峰值脉冲功率:500W@8/20μs - 工作温度:-55至+125°C - 存储温度:-55至+150°C - 焊接温度:260°C(10秒)
功能详解:该系列TVS阵列适用于以太网应用,提供多达四条线路的共模配置保护。
电路连接如下: - TPIN连接到引脚5 - TPIP连接到引脚6 - TPON连接到引脚1 - TPOP连接到引脚2
应用信息:适用于RS-232/RS-422数据线、基于微处理器的设备、笔记本电脑、台式机和服务器、局域网/广域网设备、串行和并行端口外设。
封装信息:SO-8封装,每卷2500片。
以上信息摘自SMC的PDF文档,提供了详细的技术数据和应用指南。
SMDB05LCCTR 价格&库存
很抱歉,暂时无法提供与“SMDB05LCCTR”相匹配的价格&库存,您可以联系我们找货
