EGUARD0522PTR
EGUARD0522PTR
    SMCDIODESOLUTIONS(桑德斯)
    UFDFN6
    EGUARD0522PTR
EGUARD0522PTR 数据手册
eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Description- eGuard™ The eGuard0522P* is an ultra low capacitance TVS (Transient Voltage Suppressor) array designed to protect sensitive semiconductor components from electrical overstress when interfaced to high-speed data lines. The ultra low capacitance (0.35pF typical I/O to I/O) of the eGuard0522P ensures negligible signal attenuation at data rates up to 3.5GHz. The solid-state construction ensures fast clamping of electrical overstress transients resulting from ESD (electrostatic discharge), EFT (Electrical Fast Transients) or CDE (Cable Discharge Events). In addition to ultra low capacitance, the eGuard0522P provides superior surge current capability and excellent voltage clamping performance. The surge current capability (8x20μs) is rated at 7A; approximately 33% higher than industry norms. Furthermore, the tight clamping ratio (VC/VRWM) of 1.9 (typical at 1A) ensures harmful transients are clamped quickly and close to the normal working voltage of the circuit. The super tight clamping ratio is 30% better than industry norms and ensures superior protection of sensitive integrated circuits. The eGuard0522P is designed to protect up to two data lines. It is packaged in a RoHS/WEEE compliant, 6 pin DFN that has a very low package profile of 0.55mm (nominal). The combination of ultra low capacitance, high surge capability, tight clamping ratio and low package profile make the eGuard0522P the ideal choice for today’s ESD sensitive, space constrained applications. Features • • • • • • • • • • • ESD protection in accordance with: IEC 61000-4-2 (ESD) ±17kV (air), ±12kV (contact) IEC 61000-4-5 (lightning) 7A (8/20μs) IEC 61000-4-4 (EFT) 40A (5/50ns) Tight clamping ratio, VC/VRWM, ensures superior protection High reverse surge current, IPP, capability Low idle current minimizes standby power consumption Low profile DFN package Package design optimized for high speed lines Flow-Through design Protects two I/O lines Low capacitance: 0.35pF typical (I/O to I/O) Low operating voltage: 5V Solid-state silicon-avalanche technology Mechanical Characteristics • • • • • • DFNWB1.45×1-6L 6-pin package(1.45×1.0×0.58mm) Pb-Free, Halogen Free, RoHS/WEEE Compliant Lead Pitch: 0.5mm Lead finish: NiPdAu Marking: Marking Code Packaging: Tape and Reel Applications • • • • • • High Definition Multi-Media Interface (HDMI) Digital Visual Interface (DVI) DisplayPort TM Interface MDDI Ports PCI Express eSATA Interfaces * The eGuard logo is a trademark of SMC Diode Solutions - Sangdest Microelectronics (Nanjing) Co. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Ordering Information: Device Package DFNWB1.45×1-6L (Pb-Free) eGuard0522P Shipping 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings @TA=25°C unless otherwise specified Parameter Symbol Value Unit Peak Pulse Current (tp=8/20μs) IPP 7 A ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) VESD ±17 ±12 kV TJ -55 to + 150 °C TSTG -55 to + 150 °C Operating Junction Temperature Range Storage Temperature Range Electrical Characteristics: Characteristics Reverse Stand-Off Voltage Reverse Breakdown Voltage Forward Voltage Drop Reverse Leakage Current Clamping Voltage Clamping Voltage Junction Capacitance Junction Capacitance Symbol VRWM VBR VF IR VC VC Cj Cj Condition Any I/O pin to ground @ It=1mA Any I/O pin to ground @ IF=1mA, T = 25 ℃ @VRWM = 5V, T = 25 ℃ Any I/O pin to ground @IPP = 1A, tp=8/20μs Any I/O pin to ground @IPP = 7A, tp=8/20μs Any I/O pin to ground @VR = 0V, fSIG = 1MHz Between I/O pins @VR = 0V, fSIG = 1MHz Any I/O pin to ground Min. - Typ. - Max. 5 Units V 6 - - V - 0.5 0.9 1 V μA - 9.5 10.5 V - - 17 V - 0.35 0.4 pF - 0.65 0.8 pF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Pin Configuration Pin Identification 1, 2 Input Lines 5, 6 Output Lines (No Internal Connection) 3, 4 Ground Marking Diagram: Where 522P is eGuard0522P 522P X = Part name = Marking code for data code Cautions:Molding resin Epoxy resin UL:94V-0 Part Name Information eGuard 05 22 P Suffix P = Ultra-low Capacitance Number of lines 22=2Ground/2Data Lines Max Stand-off Voltage 05=5VRWM (Volts) TVS Arrays Product • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Fig.1 Power Derating Curve Fig.2 Pulse Waveform • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Fig.3 Clamping Voltage vs. Peak Pulse Current Fig. 4 Normalized Capacitance vs. Reverse Voltage • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Green Products Technical Data Data Sheet N1683 REV.- Mechanical Dimensions (In mm/Inches): DFNWB1.45×1- 6L • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • eGuard0522P Technical Data Data Sheet N1683 REV.- Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
EGUARD0522PTR
物料型号为 eGuard0522P,是 SMC Diode Solutions 提供的一种超低电容瞬态电压抑制器(TVS)阵列。
它旨在保护高速数据线接口的敏感半导体元件免受电气过应力的损害。
器件简介: - eGuard0522P 具有超低电容(典型值 0.35pF I/O 到 I/O),确保在高达 3.5GHz 的数据速率下信号衰减极小。
- 固态结构确保了对静电放电(ESD)、电气快速瞬变(EFT)或电缆放电事件(CDE)引起的电气过应力瞬变的快速抑制。
- 提供优越的浪涌电流能力和出色的电压抑制性能,浪涌电流能力(8x20μs)为 7A,比行业标准高出约 33%。
- 紧固的钳位比(VC/VRWM)为 1.9(典型值 1A),确保有害瞬变迅速且接近电路的正常工作电压。
引脚分配: - 引脚 1,2:输入线 - 引脚 5,6:输出线(无内部连接) - 引脚 3,4:地
参数特性: - 反向偏置电压(VRWM):典型值 5V - 反向击穿电压(VBR):最小值 6V - 正向电压降(VF):典型值 0.9V - 反向漏电流(IR):典型值 1uA - 钳位电压(Vc):在 1A 时典型值 9.5V,在 7A 时典型值 17V - 结电容(C):典型值 0.35pF(I/O 之间) - 结电容(C1):典型值 0.65pF(任一 I/O 引脚到地)
功能详解: - 符合 IEC 61000-4-2(空气 ESD)±17kV 和 IEC 61000-4-2(接触 ESD)±12kV 的 ESD 保护 - 符合 IEC 61000-4-5(闪电)7A(8/20μs)和 IEC 61000-4-4(EFT)40A(5/50ns)的浪涌保护 - 具有高反向浪涌电流能力(IPP),低待机功耗的低空闲电流 - 低高度 DFN 封装,适用于高速线路的流线型设计 - 保护两条 I/O 线
应用信息: - 适用于高清多媒体接口(HDMI)、数字视觉接口(DVI)、DisplayPort 接口、MDDI 端口、PCI Express、eSATA 接口等。
封装信息: - 封装类型:DFNWB1.45x1-6L(6 引脚封装,尺寸 1.45x1.0x0.58mm) - 引脚间距:0.5mm - 引脚表面处理:NiPdAu - 标记代码:522PX(522 P 为部件名称,X 为数据代码的标记代码)
请注意,这些信息是基于 PDF 文档中的技术数据表提供的,并且可能会有所更改。
在订购前,建议联系 SMC - Sangdest Microelectronics (Nanjing) Co., Ltd 销售部门获取最新版本的数据表。
EGUARD0522PTR 价格&库存
很抱歉,暂时无法提供与“EGUARD0522PTR”相匹配的价格&库存,您可以联系我们找货
