SMAJ17ATR
SMAJ17ATR
    SMCDIODESOLUTIONS(桑德斯)
    SMC(DO-214AB)
    TVS DIODE 17VWM 27.6VC SMA
SMAJ17ATR 数据手册
SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - Green Products SMAJ SERIES SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features: • • • • • • • • • • Glass Passivated Die Construction 400W Peak Pulse Power Dissipation 5.0V- 170V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data: • • • • Case: JEDEC DO-214AC Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD 750, Method 2026 Polarity: Cathode Band or Cathode Notch Weight:0.064 grams(approx.) Mechanical Dimensions In Inches (mm) SMA/DO-214AC Dim. Min. Max. Min. Max. A 2.50 2.90 0.098 0.114 B 4.00 4.60 0.157 0.181 C 1.40 1.60 0.055 0.063 D 0.152 0.305 0.006 0.012 E 4.80 5.28 0.189 0.208 F 2.00 2.44 0.079 0.096 G 0.051 0.203 0.002 0.008 H 0.76 1.52 0.030 0.060 In mm In inch SMA • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL HD/TD YY WW L SMAJ5.0 = Part Name = Year = Week = Lot Number SMAJ5.0C Cautions Molding resin Epoxy resin UL:94V-0 Ordering Information Device Package SMA (Pb-Free) SMAJ SERIES Shipping 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C by 10x1000μs Waveform (Fig.1)(Note 1, 2, 5) Peak Forward Surge Current, 8.3ms Single Half Sine Wave ( Fig.5),(Note 3) Peak Pulse Current on 10x1000μs Waveform(Fig.2)(Note 1) Steady State Power Dissipation(Note 4) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 400 W IFSM 40 A IPPM See Table 1 A PM(AV) 1.0 W TJ,TSTG -55 to 150 °C Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5.0mm² copper pads to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4pulses per minute maximum. 4. Lead temperature at 75°C=TL 5. Peak pulse power waveform is 10x1000μs • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0223, Rev. - Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
SMAJ17ATR
物料型号:SMAJ系列,400W表面贴装瞬态电压抑制器。
器件简介:SMAJ系列瞬态电压抑制器(TVS)具有玻璃钝化二极管结构,能够承受400W的峰值脉冲功率耗散,工作电压范围为5.0V至170V,提供单向和双向版本,具有优秀的钳位能力与快速响应时间。塑料外壳材料具有UL94V-0的易燃性分类等级,是无铅设备。
引脚分配:根据JEDEC DO-214AC标准,低矮外形塑封,端子为可焊接的镀锡,符合MIL-STD-750标准。
参数特性: - 峰值脉冲功率耗散:400W - 峰值正向浪涌电流:40A - 稳态功率耗散:1.0W - 工作结温和存储温度范围:-55°C至150°C
功能详解:SMAJ系列用于保护电子设备免受电压瞬变的影响,如静电放电(ESD)、电快速瞬变(EFT)等。
应用信息:适用于多种电子设备,包括通信设备、计算机、电源、消费电子产品等。
封装信息:SMA(Pb-Free)封装,5000pcs/卷的包装方式,具体胶带和卷轴规格可参考制造商的胶带和卷轴包装规范。
SMAJ17ATR 价格&库存
很抱歉,暂时无法提供与“SMAJ17ATR”相匹配的价格&库存,您可以联系我们找货
