P6KE39ATR
P6KE39ATR
    SMCDIODESOLUTIONS(桑德斯)
    DO-15
    TVS DIODE 33.3VWM 53.9VC DO15
P6KE39ATR 数据手册
P6KE SERIES Technical Data Data Sheet N0157, Rev. B Green Products P6KE SERIES TRANSIENT VOLTAGE SUPPRESSOR Features: • • • • • • • • • • Glass Passivated Die Construction 600W Peak Pulse Power Dissipation 6.8V- 440V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data: • • • • Case: JEDEC DO-15 Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band or Cathode Notch Weight:0.41 grams(approx.) Mechanical Dimensions:In Inches (mm) DO-15 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • P6KE SERIES Technical Data Data Sheet N0157, Rev. B Green Products Marking Diagram P6KE6.8/P6KE6.8C = Part Name P6KE6.8 P6KE6.8C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device Package DO-15 (Pb-Free) P6KE SERIES Shipping 3000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C (Fig.1)(Note 1, 2, 5) Peak Forward Surge Current, 8.3ms Single Half Sine Wave Fig.6 (Note 3) Peak Pulse Current on 10x1000μs Waveform(Fig.3)(Note 1) Steady State Power Dissipation( Note 2, 4) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 600 W IFSM 100 A IPPM See Table 1 A PM(AV) 5.0 W TJ,TSTG -55 to + 175 °C Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 40mm² copper pad. 3. 8.3ms Single Half Sine Wave duty cycle = 4 pulses per minutes maximum 4. Lead temperature at 75°C= TL 3. Peak pulse power waveform is 10/1000μs. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • P6KE SERIES Technical Data Data Sheet N0157, Rev. B • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products P6KE SERIES Technical Data Data Sheet N0157, Rev. B “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products P6KE SERIES Technical Data Data Sheet N0157, Rev. B “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products P6KE SERIES Technical Data Data Sheet N0157, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
P6KE39ATR
物料型号:P6KE系列 器件简介:P6KE系列是瞬态电压抑制二极管,具有玻璃钝化芯片结构,能够承受600W的峰值脉冲功率耗散,工作电压范围在6.8V至440V之间。它们有单向和双向版本,具有优秀的钳位能力、快速响应时间,并且塑料外壳材料具有UL阻燃分类94V-0等级。这些设备是无铅的,所有SMC部件都可以追溯到晶圆批次。
引脚分配:P6KE系列采用JEDEC DO-15低矮外形塑封,端子为镀锡,符合MIL-STD-202标准方法208,极性通过阴极带或阴极凹槽标识。
参数特性:包括峰值脉冲功率耗散、峰值正向浪涌电流、峰值脉冲电流、稳态功率耗散、工作结和存储温度范围等。
功能详解:P6KE系列用于抑制电路中的瞬态电压,保护电子设备免受电压尖峰的损害。
应用信息:适用于多种电子设备,以保护它们免受电压尖峰的影响。
封装信息:提供详细的机械尺寸数据,包括英寸和毫米单位。
P6KE39ATR 价格&库存
很抱歉,暂时无法提供与“P6KE39ATR”相匹配的价格&库存,您可以联系我们找货
