1.5KE20CATA
1.5KE20CATA
    SMCDIODESOLUTIONS(桑德斯)
    DO201AD
    TVSDIODE17.1VWM27.7VCDO201AD
1.5KE20CATA 数据手册
1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Green Products Technical Data Data Sheet N0209, Rev. D 1.5KE SERIES TRANSIENT VOLTAGE SUPPRESSOR Features:           Glass Passivated Die Construction 1500W Peak Pulse Power Dissipation 6.8V- 440V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data:     Case: JEDEC DO-201AD Low Profile Molded Plastic Terminals: Axial Leads, Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band or Cathode Notch Weight: 1.10 grams(approx.) Mechanical Dimensions:In Inches (mm) DO-201AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Green Products Technical Data Data Sheet N0209, Rev. D Marking Diagram 1.5KE6.8/1.5KE6.8C = Part Name 1.5KE6.8 1.5KE6.8C Note: Starting from the 16XXX will not mark date code. Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device Package DO-201AD (Pb-Free) 1.5KE SERIES Shipping 1250pcs / Tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C (Fig.1)(Note 1, 2, 5) Peak Forward Surge Current per Fig.6(Note 3) Peak Pulse Current on 10x1000μs Waveform(Fig.3)(Note 1) Steady State Power Dissipation(Note 2, 4) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 1500 W IFSM 200 A IPPM See Table 1 A PM(AV) 5.0 W TJ,TSTG -65 to 175 °C Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 20mm² copper pad 3. 8.3ms single half sine wave duty cycle=4 pulses per minute maximum. 4. Lead temperature at 75°C=TL 5. Peak pulse power waveform is 10x1000μs  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0209, Rev. D  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0209, Rev. D “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0209, Rev. D “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1.5KE SERIES 1500W TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0209, Rev. D Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1.5KE20CATA
物料型号:1.5KE系列
器件简介:1.5KE系列瞬态电压抑制二极管(TVS),具有1500W的峰值脉冲功率耗散能力,工作电压范围从6.8V至440V,提供单向和双向版本,具有出色的钳位能力、快速响应时间,并且是无铅环保产品。
引脚分配:器件采用JEDEC DO-201AD低矮外形塑封,具有轴向引脚,阴极带有色环或凹槽以标识极性。
参数特性:包括但不限于峰值脉冲功率耗散(PPPM)、峰值正向浪涌电流(IFSM)、峰值脉冲电流(IPPM)、稳态功率耗散(PM(AV))以及工作结和存储温度范围(TJ,TSTG)。
功能详解:瞬态电压抑制二极管主要用于保护电子设备免受电压瞬变的影响,如静电放电(ESD)、电快速瞬变(EFT)等。
应用信息:适用于多种应用,包括电源保护、数据线保护、信号线保护等。
封装信息:封装类型为DO-201AD,塑封材料具有UL94V-0的阻燃等级,器件重量约为1.10克。
1.5KE20CATA 价格&库存
很抱歉,暂时无法提供与“1.5KE20CATA”相匹配的价格&库存,您可以联系我们找货
