SMCJ7.0CATR
SMCJ7.0CATR
    SMCDIODESOLUTIONS(桑德斯)
    SMC(DO-214AB)
    TVSDIODE7VWM12VCSMC
SMCJ7.0CATR 数据手册
SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B Green Products SMCJ SERIES SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features: • • • • • • • • • • Glass Passivated Die Construction 1500W Peak Pulse Power Dissipation 5.0V- 170V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Case Material has UL Flammability Classification Rating 94V-O This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data: • • • • Case: JEDEC DO-214AB Low Profile Molded Plastic Terminals: Solder Plated , Solderable per MIL-STD 750, Method 2026 Polarity: Cathode Band or Cathode Notch Weight:0.21 grams(approx.) Mechanical Dimensions:In Inches (mm) SMC/DO-214AB Dim. Min. Max. Min. Max. A 5.59 6.22 0.220 0.245 B 6.60 7.11 0.260 0.280 C 2.75 3.25 0.108 0.128 D 0.152 0.305 0.006 0.012 E 7.75 8.25 0.305 0.325 F 2.00 2.95 0.079 0.116 G 0.051 0.203 0.002 0.008 H 0.76 1.60 0.030 0.063 In mm In inch SMC • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL GDD/BDD YY WW L = Part Name = Year = Week = Lot Number SMCJ5.0C SMCJ5.0 Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information Device Package SMC (Pb-Free) SMCJ SERIES Shipping 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation at TA=25°C by 10x1000μs Waveform (Fig.1)(Note 1), (Note 2) Peak Pulse Current on 10x1000μs Waveform (Note 1) (Fig.3) Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 2),(Note 3) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 1500 W IPPM See Table 1 A IFSM 200 A TJ,TSTG -55 to +150 °C Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 8.0mm² copper pads to each terminal. 3. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4pulses per minute maximum. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Green Products SMCJ SERIES 1500W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0002, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com •
SMCJ7.0CATR
物料型号:SMCJ系列 器件简介:1500W表面贴装瞬态电压抑制器(Surface Mount Transient Voltage Suppressor),具有玻璃钝化二极管结构,提供高达1500W的峰值脉冲功率耗散,适用于5.0V至170V的隔离电压,有单向和双向版本,具有优秀的钳位能力、快速响应时间,塑料外壳材料具有UL可燃性分类等级94V-0。
引脚分配:文档中提到了极性标识,阴极带或阴极缺口。
参数特性:包括峰值脉冲功率耗散(PPPM)、峰值脉冲电流(IPPM)、正向浪涌电流(IFSM)、工作结温和存储温度范围(TJ,TSTG)等。
功能详解:文档提供了脉冲耗散曲线图、典型结电容图、脉冲等级曲线图和脉冲波形图,以展示器件的性能。
应用信息:适用于需要瞬态电压保护的场合,例如电源线、数据线等。
封装信息:JEDEC DO-214AB低轮廓模塑塑料外壳,端子为可焊接的,符合MIL-STD 750标准。
SMCJ7.0CATR 价格&库存
很抱歉,暂时无法提供与“SMCJ7.0CATR”相匹配的价格&库存,您可以联系我们找货
