15KPA160ATR
15KPA160ATR
    SMCDIODESOLUTIONS(桑德斯)
    R-6(P-600)
    TVSDIODE160VWM258.6VCP-600
15KPA160ATR 数据手册
15KPA SERIES GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR Green Products Technical Data Data Sheet N0215, Rev. D Features:             Plastic package has Underwriters Laboratory Flammability Classification 94V-O Glass Passivated Junction 15000W Peak Pulse Power Capability on 10/1000 μs waveform Voltage-17.0 to 280 Volts Excellent Clamping Capability Repetition rate (duty cycle): 0.05% Low incremental surge resistance Fast Response Time: typically less than 1.0 ps from 0 volts to BV High temperature soldering guaranteed: 265℃/10 seconds/.375”, (9.5mm) lead length, 5lbs., (2.3kg) tension This is a Pb − Free Device All SMC Parts are Traceable to the Wafer Lot Additional testing can be offered upon request Mechanical Data:      Case: Molded Plastic over glass passivated junction Terminals: Plated Axial leads , Solderable per MIL-STD 750, Method 2026 Polarity: Color Band denoted positive end (cathode) except Bipolar Mounting Position: Any Weight:0.064 grams(approx.) Mechanical Dimensions:In Inches (mm) P-600  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  15KPA SERIES GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR Green Products Technical Data Data Sheet N0215, Rev. D MARKING DIAGRAM Where XXXXX is YYWWL 15KPA17A YY WW L = Part Name = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping 15KPAxxxXX P-600(Pb-Free) 300pcs /tape 15KPAxxxXXTR P-600(Pb-Free) 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Parameter Peak Pulse Power Dissipation on 10x1000μs Waveform(Note 1) Peak Pulse Current on 10x1000μs Waveform(Note 1) Steady State Power Dissipation at TL=75°C Lead Lengths .375”, (9.5mm)(Note 2) Peak Forward Surge Current, 8.3ms SineWave Superimposed on Rated Load, (JEDEC Method)(Note 3) Operating Junction and Storage Temperature Range Symbol Value Unit PPPM 15000 W IPPM See Table 1 A PM(AV) 8.0 W IFSM 400.0 A TJ,TSTG -55 to 175 °C Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on copper pad area of 0.8” × 0.8” (20 × 20mm) 3. 8.3ms single half sine wave, or equivalent square, duty cycle=4 pulses per minute maximum.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  15KPA SERIES GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0215, Rev. D For bidirectional type having VRWM of 30 volts and less, the IR limit is double. For parts without A, the VBR is + 10% and Vc is 5% higher than with A parts  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 15KPA SERIES GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0215, Rev. D  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 15KPA SERIES GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR Technical Data Data Sheet N0215, Rev. D Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
15KPA160ATR
物料型号:15KPA系列
器件简介:15KPA系列是玻璃钝化瞬态电压抑制二极管,具有15000W的峰值脉冲功率能力,适用于10/1000μs波形。这些二极管具有优异的钳位能力、低增量浪涌电阻、快速响应时间(典型值小于1.0皮秒),并且保证在高温下焊接。
引脚分配:文档中没有明确指出引脚分配,但通常瞬态电压抑制二极管具有阳极和阴极两个引脚。
参数特性: - 峰值脉冲功率:15000W - 工作电压范围:17.0至280伏特 - 重复率(占空比):0.05% - 存储和工作结温范围:-55°C至175°C
功能详解:15KPA系列二极管设计用于保护电子设备免受电压瞬变的影响,如电源线、数据线和信号线等。
应用信息:适用于电源线、数据线和信号线的保护,以及其他需要瞬态电压抑制的应用。
封装信息:封装为模塑塑料,覆盖在玻璃钝化结上。引脚为镀层轴向引线,符合MIL-STD 750标准,可焊接。
15KPA160ATR 价格&库存
很抱歉,暂时无法提供与“15KPA160ATR”相匹配的价格&库存,您可以联系我们找货
