15KPA SERIES
GLASS PASSIVATED TRANSIENT VOLTAGE SUPPRESSOR
Green Products
Technical Data
Data Sheet N0215, Rev. D
Features:
Plastic package has Underwriters Laboratory Flammability Classification 94V-O
Glass Passivated Junction
15000W Peak Pulse Power Capability on 10/1000 μs waveform
Voltage-17.0 to 280 Volts
Excellent Clamping Capability
Repetition rate (duty cycle): 0.05%
Low incremental surge resistance
Fast Response Time: typically less than 1.0 ps from 0 volts to BV
High temperature soldering guaranteed: 265℃/10 seconds/.375”, (9.5mm) lead length, 5lbs.,
(2.3kg) tension
This is a Pb − Free Device
All SMC Parts are Traceable to the Wafer Lot
Additional testing can be offered upon request
Mechanical Data:
Case: Molded Plastic over glass passivated junction
Terminals: Plated Axial leads , Solderable per MIL-STD 750, Method 2026
Polarity: Color Band denoted positive end (cathode) except Bipolar
Mounting Position: Any
Weight:0.064 grams(approx.)
Mechanical Dimensions:In Inches (mm)
P-600
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
15KPA SERIES
Green Products
Technical Data
MARKING DIAGRAM
Where XXXXX is YYWWL
15KPA17A
YY
WW
L
= Part Name
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
Shipping
15KPAxxxXX
P-600(Pb-Free)
300pcs /tape
15KPAxxxXXTR
P-600(Pb-Free)
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Parameter
Peak Pulse Power Dissipation on
10x1000μs Waveform(Note 1)
Peak Pulse Current on 10x1000μs
Waveform(Note 1)
Steady State Power Dissipation at
TL=75°C Lead Lengths .375”,
(9.5mm)(Note 2)
Peak Forward Surge Current, 8.3ms SineWave Superimposed on Rated Load,
(JEDEC Method)(Note 3)
Operating Junction and Storage
Temperature Range
Symbol
Value
Unit
PPPM
15000
W
IPPM
See Table 1
A
PM(AV)
8.0
W
IFSM
400.0
A
TJ,TSTG
-55 to 175
°C
Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on copper pad area of 0.8” × 0.8” (20 × 20mm)
3. 8.3ms single half sine wave, or equivalent square, duty cycle=4 pulses per minute maximum.
15KPA SERIES
Technical Data
For bidirectional type having VRWM of 30 volts and less, the IR limit is double.
For parts without A, the VBR is + 10% and Vc is 5% higher than with A parts
Green Products
15KPA SERIES
Technical Data
Green Products
15KPA SERIES
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“15KPA100CATR”相匹配的价格&库存,您可以联系我们找货
