PV275K3225T
PV275K3225T
    SEI
    SMD2_8X6MM
    钳位电压710V 13焦耳 贴片压敏电阻
PV275K3225T 数据手册
PV Series Stackpole Electronics, Inc. Low & Medium Voltage Plastic Encapsulated SMD Varistor Resistive Product Solutions Description: The PV Series is a line of surface mount plastic-encapsulated varistors designed to protect electronic equipment against high voltage surges in the low and medium voltage region. They offer direct SMD equivalents to 5mm and 7mm leaded disc varistors. The thermoplastic encapsulation is non-flammable according to the standard defined by UL94V-0. Terminations are tinned copper sheet. PV varistors are designed exclusively for surface mounting and are available in two model sizes. These transient voltage suppressors cover operating voltages (Vrms) from 11V to 300V and feature maximum surge currents from 100A to 1,200A. Features: • • • • • • • • • AC operating voltage (Vrms) from 11V to 300V DC operating voltage (Vdc) from 14V to 385V Insensitive to water cleaning procedures and to humidity according to the climate category 55/125/56 +85ºC continuous operating temperature Non-flammable thermoplastic encapsulation case according to standard UL94V-0 2 model sizes available: 3225 and 4032 Dimensional and weight savings on board Easily solderable tinned copper terminations UL, CAC, CEDD approved General Technical Data Climatic Category 55 / 125 / 56 In accordance with IEC 60068-1 Operating Temperature -40ºC to +85ºC In accordance with CECC 42 000 Storage Temperature Range -40ºC to +125ºC Threshold Voltage Temperature Coefficient ≤0.05% / ºC Response Time < 5 nS Standard Packaging Options / Quantities Series Voltage Range (Vrms) PV 11 - 150 175 - 300 Chip Size 3225 4032 1,500 1,000 1,000 1,000 How to Order PV 1 2 3 4 5 6 7 8 9 10 P V 4 0 K 3 2 2 5 T Product Series Low & Medium Voltage Plastic Encapsulated SMD Varistor Vrms 40 Tolerance Code Tol K 10% S Special Rev Date: 08/15/2011 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 Chip Size 3225 4032 Code T Packaging Description Tape and Reel www.seielect.com marketing@seielect.com PV Series Low & Medium Voltage Plastic Encapsulated SMD Varistor Stackpole Electronics, Inc. Resistive Product Solutions Device Ratings and Dimensions Part Number VRMS (volts) VDC (volts) PV 11 K 3225 PV 11 K 4032 PV 14 K 3225 PV 14 K 4032 PV 17 K 3225 PV 17 K 4032 PV 20 K 3225 PV 20 K 4032 PV 25 K 3225 PV 25 K 4032 PV 30 K 3225 PV 30 K 4032 PV 35 K 3225 PV 35 K 4032 PV 40 K 3225 PV 40 K 4032 PV 50 K 3225 PV 50 K 4032 PV 60 K 3225 PV 60 K 4032 PV 75 K 3225 PV 75 K 4032 PV 95 K 3225 PV 95 K 4032 PV 115 K 3225 PV 115 K 4032 PV 130 K 3225 PV 130 K 4032 PV 140 K 3225 PV 140 K 4032 PV 150 K 3225 PV 150 K 4032 PV 175 K 3225 PV 175 K 4032 PV 230 K 3225 PV 230 K 4032 PV 250 K 3225 PV 250 K 4032 PV 275 K 3225 PV 275 K 4032 PV 300 K 3225 PV 300 K 4032 11 11 14 14 17 17 20 20 25 25 30 30 35 35 40 40 50 50 60 60 75 75 95 95 115 115 130 130 140 140 150 150 175 175 230 230 250 250 275 275 300 300 14 14 18 18 22 22 26 26 31 31 38 38 45 45 56 56 65 65 85 85 100 100 125 125 150 150 170 170 180 180 200 200 225 225 300 300 320 320 350 350 385 385 Vn @ 1mA (volts) 18 18 22 22 27 27 33 33 39 39 47 47 56 56 68 68 82 82 100 100 120 120 150 150 180 180 205 205 220 220 240 240 270 270 360 360 390 390 430 430 470 470 VC (volts) IC (amps) W MAX (joules) PMAX (watts) 36 36 43 43 53 53 65 65 77 77 93 93 110 110 135 135 135 135 165 165 200 200 250 250 300 300 340 340 360 360 395 395 455 455 595 595 650 650 710 710 775 775 2.5 5.0 2.5 5.0 2.5 5.0 2.5 5.0 2.5 5.0 2.5 5.0 2.5 5.0 2.5 5.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 0.6 1.1 0.7 1.3 0.9 1.6 1.1 2.0 1.2 2.4 1.5 2.8 1.8 3.4 2.2 4.1 2.5 6.5 3.0 7.0 4.0 9.0 6.0 11.0 6.5 13.0 7.0 15.0 7.5 18.0 9.0 18.5 9.5 21.0 10.0 23.0 11.0 25.0 13.0 29.0 15.0 30.0 0.01 0.02 0.01 0.02 0.01 0.02 0.01 0.02 0.01 0.02 0.01 0.02 0.01 0.02 0.01 0.02 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 Rev Date: 08/15/2011 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 Imax CTYP h L W t 8/20 μs (amps) @ 1kHz (pF) ± 0.3 (mm) ± 0.5 (mm) ± 0.4 (mm) ± 0.3 (mm) 100 250 100 250 100 250 100 250 100 250 100 250 100 250 100 250 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 1,600 3,100 1,300 2,500 1,050 1,900 750 1,500 660 1,260 580 1,050 460 850 400 720 390 820 330 680 270 550 220 440 180 360 160 320 150 300 140 280 120 250 95 190 80 180 75 160 70 150 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 www.seielect.com marketing@seielect.com
PV275K3225T 价格&库存
很抱歉,暂时无法提供与“PV275K3225T”相匹配的价格&库存,您可以联系我们找货
PV275K3225T
    库存:2000
    PV275K3225T
    • 1000+3.318311000+0.42984
    • 2000+3.211462000+0.41600
    • 3000+3.157933000+0.40907
    • 5000+3.098635000+0.40138
    • 7000+3.063997000+0.39690
    • 10000+3.0306510000+0.39258
    库存:1080
    PV275K3225T
    • 1+6.879591+0.89115
    • 10+4.9127810+0.63638
    • 25+4.4174425+0.57222
    • 100+3.86772100+0.50101
    • 250+3.60576250+0.46708
    • 500+3.44824500+0.44667
    库存:1080
    PV275K3225T
    • 1000+6.196171000+0.80262
    库存:7000
