PV Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Low & Medium Voltage Plastic Encapsulated SMD Varistor
Description:
The PV Series is a line of surface mount plastic-encapsulated varistors designed
to protect electronic equipment against high voltage surges in the low and medium
voltage region. They offer direct SMD equivalents to 5 mm and 7 mm leaded disc
varistors. The thermoplastic encapsulation is non-flammable according to the
standard defined by UL94V-0. Terminations are tinned copper sheet.
PV varistors are designed exclusively for surface mounting and are available in
two model sizes. These transient voltage suppressors cover operating voltages
(Vrms) from 60 V to 300 V and feature maximum surge currents from 100A to
1,200A.
Features:
AC operating voltage (Vrms) from 60 V to 300 V
DC operating voltage (Vdc) from 85 V to 385 V
Insensitive to water cleaning procedures and to humidity according to the climate category 55/125/56
+85ºC continuous operating temperature
Non-flammable thermoplastic encapsulation case according to standard UL94V-0
2 model sizes available: 3225 and 4032
Dimensional and weight savings on board
Easily solderable tinned copper terminations
UL1449, 3rd Ed. and CSA C22.2 certified
RoHS compliant, lead-free and halogen-free
Electrical Specifications
Climatic Category
Operating Temperature
Storage Temperature Range
Threshold Voltage Temperature Coefficient
Response Time
55 / 125 / 56
-40 ºC to +85 ºC
-40 ºC to +125 ºC
≤0.05% / ºC
< 5 nS
Standard Packaging Options / Quantities
Series
Voltage Range (Vrms)
PV
60 - 150
175 - 300
Chip Size
3225
1,500
1,000
4032
1,000
1,000
Device Ratings and Dimensions
Part Number
VRMS
(volts)
VDC
(volts)
PV60K3225
PV60K4032
PV75K3225
PV75K4032
60
60
75
75
85
85
100
100
Vn
@ 1mA
(volts)
100
100
120
120
VC
(volts)
IC
(amps)
WMAX
(joules)
PMAX
(watts)
165
165
200
200
5.0
10.0
5.0
10.0
3.0
7.0
4.0
9.0
0.10
0.25
0.10
0.25
Rev Date: 08/28/2019
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
Imax
8/20 μs
(amps)
400
1,200
400
1,200
CTYP
@ 1kHz
(pF)
330
680
270
550
h
± 0.3
(mm)
1.70
2.30
1.70
2.30
L
± 0.5
(mm)
8.0
10.0
8.0
10.0
W
± 0.4
(mm)
6.3
8.0
6.3
8.0
t
± 0.3
(mm)
3.4
4.7
3.4
4.7
www.seielect.com
marketing@seielect.com
PV Series
Device Ratings and Dimensions (cont.)
Part Number
VRMS
(volts)
VDC
(volts)
PV95K3225
PV95K4032
PV115K3225
PV115K4032
PV130K3225
PV130K4032
PV140K3225
PV140K4032
PV150K3225
PV150K4032
PV175K3225
PV175K4032
PV230K3225
PV230K4032
PV250K3225
PV250K4032
PV275K3225
PV275K4032
PV300K3225
PV300K4032
95
95
115
115
130
130
140
140
150
150
175
175
230
230
250
250
275
275
300
300
125
125
150
150
170
170
180
180
200
200
225
225
300
300
320
320
350
350
385
385
Vn
@ 1mA
(volts)
150
150
180
180
205
205
220
220
240
240
270
270
360
360
390
390
430
430
470
470
VC
(volts)
IC
(amps)
WMAX
(joules)
PMAX
(watts)
250
250
300
300
340
340
360
360
395
395
455
455
595
595
650
650
710
710
775
775
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
5.0
10.0
6.0
11.0
6.5
13.0
7.0
15.0
7.5
18.0
9.0
18.5
9.5
21.0
10.0
23.0
11.0
25.0
13.0
29.0
15.0
30.0
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
0.10
0.25
Imax
8/20 μs
(amps)
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
400
1,200
CTYP
@ 1kHz
(pF)
220
440
180
360
160
320
150
300
140
280
120
250
95
190
80
180
75
160
70
150
h
± 0.3
(mm)
1.70
2.30
1.70
2.30
1.70
2.30
1.70
2.30
1.70
2.30
2.30
2.30
2.30
2.30
2.30
2.30
2.30
2.30
2.30
2.30
L
± 0.5
(mm)
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
8.0
10.0
W
± 0.4
(mm)
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
6.3
8.0
t
± 0.3
(mm)
3.4
4.7
3.4
4.7
3.4
4.7
3.4
4.7
3.4
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
PV
Low and Medium Voltage Plastic
Package /
Standard
Termination Series RoHS
Type
Compliant
SMD
YES
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
100% Matte Sn
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
2
www.seielect.com
PV Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
PV
1
2
3
4
5
6
7
8
9
10
P
V
6
K
3
2
2
5
T
Product Series
SMD Varistor
Vrms
60 - 150
Tolerance
Code
Tol
K
10%
S
Special
3
Chip Size
3225
4032
Code
T
Packaging
Description
Tape and Reel
www.seielect.com
很抱歉,暂时无法提供与“PV150K4032T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+4.295871000+0.55574
- 2000+4.163482000+0.53861
- 3000+4.097193000+0.53004
- 5000+4.023695000+0.52053
- 7000+3.980737000+0.51497
- 10000+3.9394510000+0.50963
- 国内价格 香港价格
- 1+8.765011+1.13389
- 10+6.2746410+0.81172
- 25+5.6571325+0.73184
- 100+4.97658100+0.64380
- 250+4.65211250+0.60183
- 500+4.45687500+0.57657
