PV275K4032T
PV275K4032T
    SEI
    SMD2_8X6MM
    钳位电压710V 29焦耳 贴片压敏电阻
PV275K4032T 数据手册
PV Series Stackpole Electronics, Inc. Resistive Product Solutions Low & Medium Voltage Plastic Encapsulated SMD Varistor Description: The PV Series is a line of surface mount plastic-encapsulated varistors designed to protect electronic equipment against high voltage surges in the low and medium voltage region. They offer direct SMD equivalents to 5 mm and 7 mm leaded disc varistors. The thermoplastic encapsulation is non-flammable according to the standard defined by UL94V-0. Terminations are tinned copper sheet. PV varistors are designed exclusively for surface mounting and are available in two model sizes. These transient voltage suppressors cover operating voltages (Vrms) from 60 V to 300 V and feature maximum surge currents from 100A to 1,200A. Features: • • • • • • • • • • AC operating voltage (Vrms) from 60 V to 300 V DC operating voltage (Vdc) from 85 V to 385 V Insensitive to water cleaning procedures and to humidity according to the climate category 55/125/56 +85ºC continuous operating temperature Non-flammable thermoplastic encapsulation case according to standard UL94V-0 2 model sizes available: 3225 and 4032 Dimensional and weight savings on board Easily solderable tinned copper terminations UL1449, 3rd Ed. and CSA C22.2 certified RoHS compliant, lead-free and halogen-free Electrical Specifications Climatic Category Operating Temperature Storage Temperature Range Threshold Voltage Temperature Coefficient Response Time 55 / 125 / 56 -40 ºC to +85 ºC -40 ºC to +125 ºC ≤0.05% / ºC < 5 nS Standard Packaging Options / Quantities Series Voltage Range (Vrms) PV 60 - 150 175 - 300 Chip Size 3225 1,500 1,000 4032 1,000 1,000 Device Ratings and Dimensions Part Number VRMS (volts) VDC (volts) PV60K3225 PV60K4032 PV75K3225 PV75K4032 60 60 75 75 85 85 100 100 Vn @ 1mA (volts) 100 100 120 120 VC (volts) IC (amps) WMAX (joules) PMAX (watts) 165 165 200 200 5.0 10.0 5.0 10.0 3.0 7.0 4.0 9.0 0.10 0.25 0.10 0.25 Rev Date: 08/28/2019 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 Imax 8/20 μs (amps) 400 1,200 400 1,200 CTYP @ 1kHz (pF) 330 680 270 550 h ± 0.3 (mm) 1.70 2.30 1.70 2.30 L ± 0.5 (mm) 8.0 10.0 8.0 10.0 W ± 0.4 (mm) 6.3 8.0 6.3 8.0 t ± 0.3 (mm) 3.4 4.7 3.4 4.7 www.seielect.com marketing@seielect.com PV Series Stackpole Electronics, Inc. Resistive Product Solutions Low & Medium Voltage Plastic Encapsulated SMD Varistor Device Ratings and Dimensions (cont.) Part Number VRMS (volts) VDC (volts) PV95K3225 PV95K4032 PV115K3225 PV115K4032 PV130K3225 PV130K4032 PV140K3225 PV140K4032 PV150K3225 PV150K4032 PV175K3225 PV175K4032 PV230K3225 PV230K4032 PV250K3225 PV250K4032 PV275K3225 PV275K4032 PV300K3225 PV300K4032 95 95 115 115 130 130 140 140 150 150 175 175 230 230 250 250 275 275 300 300 125 125 150 150 170 170 180 180 200 200 225 225 300 300 320 320 350 350 385 385 Vn @ 1mA (volts) 150 150 180 180 205 205 220 220 240 240 270 270 360 360 390 390 430 430 470 470 VC (volts) IC (amps) WMAX (joules) PMAX (watts) 250 250 300 300 340 340 360 360 395 395 455 455 595 595 650 650 710 710 775 775 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 5.0 10.0 6.0 11.0 6.5 13.0 7.0 15.0 7.5 18.0 9.0 18.5 9.5 21.0 10.0 23.0 11.0 25.0 13.0 29.0 15.0 30.0 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 0.10 0.25 Imax 8/20 μs (amps) 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 400 1,200 CTYP @ 1kHz (pF) 220 440 180 360 160 320 150 300 140 280 120 250 95 190 80 180 75 160 70 150 h ± 0.3 (mm) 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 1.70 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 2.30 L ± 0.5 (mm) 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 W ± 0.4 (mm) 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 6.3 8.0 t ± 0.3 (mm) 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 3.4 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description PV Low and Medium Voltage Plastic Encapsulated SMD Varistor Package / Standard Termination Series RoHS Type Compliant SMD YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) 100% Matte Sn Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 08/28/2019 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com PV Series Stackpole Electronics, Inc. Resistive Product Solutions Low & Medium Voltage Plastic Encapsulated SMD Varistor Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order PV 1 2 3 4 5 6 7 8 9 10 P V 6 0 K 3 2 2 5 T Product Series Low & Medium Voltage Plastic Encapsulated SMD Varistor Vrms 60 - 150 Tolerance Code Tol K 10% S Special Rev Date: 08/28/2019 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 Chip Size 3225 4032 Code T Packaging Description Tape and Reel www.seielect.com marketing@seielect.com
PV275K4032T 价格&库存
很抱歉,暂时无法提供与“PV275K4032T”相匹配的价格&库存,您可以联系我们找货
PV275K4032T
    PV275K4032T
      PV275K4032T
      • 1000+4.285071000+0.55613
      • 2000+4.153002000+0.53899
      • 3000+4.086883000+0.53041
      • 5000+4.013575000+0.52089
      • 7000+3.970727000+0.51533
      • 10000+3.9295310000+0.50999
      库存:1182
      PV275K4032T
      • 1+8.743211+1.13471
      • 10+6.2590310+0.81231
      • 25+5.6430525+0.73237
      • 100+4.96409100+0.64425
      • 250+4.64041250+0.60224
      • 500+4.44565500+0.57697
      库存:1182
