BPM750WE
BPM750WE
    EATON(伊顿)
    BPM750WE
BPM750WE 数据手册
Technical data 2092 Effective December 2015 Supersedes June 2011 BUSSMANN SERIES 1-Pole IEC Class I coordinated lightning current arresters for 75V to 1000V TN and TT wind power systems TN and 1-phase TT system arresters The features of these single-pole devices are for use as a single device or in combination with other devices. TT system arresters Remote contact signaling available Provide a current arresting means between neutral conductor and protective conductor in TT systems. These devices help ensure fulfilling the requirements for protection of personnel and equipment in “3+1” and “1+1” circuits. Optional remote contact signaling easyID™ local visual status indication The three-pole terminal remote contact signaling option has a floating changeover contact for use as a break or make contact, according to circuit concept. Specifications: System volts t Catalog symbol: 75Vac to 1000Vac (see ordering information table for details) t BSPG1230WE System types t BSPG1230WER t TN t BSPM_WE t TT t BSPM_WER Agency information Description: Eaton’s Bussman™ series of one-pole IEC Class II modular surge arresters feature local, easyID™ visual indication and optional remote contact signaling. The unique module locking system on the 75 to 690 volt arresters fixes the protection module to the base part. Modules can be easily replaced without tools by simply depressing the release buttons. Integrated mechanical coding between the base and protection module ensures against installing an incorrect replacement module. t CE t CSA t KEMA t RoHS compliant Mounting t 35mm DIN-Rail Warranty t Five years Technical Data 2092 1-Pole IEC Class II surge arresters for 75V-1000V TN and TT wind power systems Effective December 2015 Dimensions - mm: Module circuit diagrams: 75V to 690V Shown with optional remote contact signaling. Gas discharge tube (single) Thermal disconnecter MOV BSPM175WE(R) BSPM1400WE(R) BSPM1690WE(R) 1000V BSPG1230WE(R) BSPM11000WE(R) Shown with optional remote contact signaling. 2 Eaton.com/bussmannseries Technical Data 2092 1-Pole IEC Class II surge arresters for 75V-1000V TN and TT wind power systems Effective December 2015 Ordering information: System voltage (50-60Hz) / poles Max. Continuous Operating Voltage (MCOV) [UC] AC (50-60Hz) W/ remote signaling Catalog numbers (base + modules) W/ remote signaling Replacement modules Specifications Line system type Max. continuous operating DC voltage [UC] Rated varistor voltage AC [Umov] Nominal discharge current (8/20μs) [In] Max. discharge current (8/20μs) [Imax] Follow current extinguishing capability [Ifi] Lightning impulse current (10/350μs) [Iimp] Voltage protection level [UP] [UP] at 5kA Response time [tA] Max. mains-side overcurrent protection Short-circuit withstand capability for max. mains-side overcurrent protection (ISCCR) Withstand Temporary Overvoltage (TOV) [UT] Safe failure Agency information Capacity (DIN 43880) SPD according to Operating environment [TU] Operating state/fault indication Number of ports Min. Cross-Sectional Area Max. Mounting Enclosure material Location category Degree of protection Product warranty 75V / 1 230V / 1 400V / 1 400V†/690V†† / 1 1000V / 1 75V 255V 440V 600V 1000V BSPM175WE BSPG1230WE BSPM1400WE BSPM1690WE BSPM11000WE BSPM175WER BSPG1230WER BSPM1400WER BSPM1690WER BSPM11000WER BPM75WE BPG255NPEWE* BPM440WE BPM750WE N/A TN / TT TT TN / TT TN / TT TN / TT 100V — 585 600V 1000V — 10kA 40kA — — ) 0.4kV ) 0.35kV ) 25 ns 125A gG — 20kA 40kA 100 Arms 12kA ) 1.5kV — ) 100 ns — — 20kA 40kA — — ) 2.0kV ) 1.7kV ) 25 ns 125A gG 750V 15kA 25kA — — ) 3kV ) 2.5kV ) 25 ns 100A gG 1000V 15kA 30kA — — ) 4.2kV ) 3.5kV ) 25 ns 100A aM** 50kArms — 25kArms 25kArms 25kArms 90V / 5 sec. 1200V / 200ms 580V / 5 sec. 900V / 5 sec. 1000V / 5 sec. KEMA, CSA 1 Mod. — 2 Mod. KEMA, CSA KEMA KEMA, CSA 1 Mod. 1 Mod. 1 Mod. EN 61643-11 Type 2, IEC 61643-11 Class II -40°C to +80°C, 5% to 95% RH Green (good) / Red (replace) 1 1.5mm2 / 14AWG solid / flexible 35mm2 / 2AWG stranded-25mm2 / 4AWG flexible 35mm DIN-Rail per EN 60715 Thermoplastic, UL 94V0 Indoor IP20 (built-in) Five years*** Remote contact signaling Remote contact signaling type Changeover contact AC 250V / 0.5A Switching capacity (volts/mps) DC 250V / 0.1A; 125V / 0.2A; 75V / 0.5A Conductor ratings and cross-sectional area 60/75°C Max. 1.5mm2 / 14AWG solid / flexible Ordering information Order from catalog numbers above * ** *** † †† N-PE surge arrester for location between neutral conductor and protective conductor in TT systems. 125A gG @ 690Vac. See Eaton’s Bussmann series SPD limited warranty statement (3A1502) for details at www.cooperbussmann.com/surge. 400V [L-N] 690V [L-L] Recommended Bussmann series NH DIN back up fuses Size Fuse catalog number 00 100NHG00B-690 00 125NHG00B-690 Eaton.com/bussmannseries 3 Technical Data 2092 1-Pole IEC Class II surge arresters for 75V-1000V TN and TT wind power systems Effective December 2015 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2092 — MC-SB15XXX December 2015 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Follow us on social media to get the latest product and support information.
BPM750WE 价格&库存
很抱歉,暂时无法提供与“BPM750WE”相匹配的价格&库存,您可以联系我们找货
