ESDU02A5V5R17V
ESDU02A5V5R17V
    SEI
    ESDU02A5V5R17V
ESDU02A5V5R17V 数据手册
ESD/ESDU Series Stackpole Electronics, Inc. Low and Ultra Low Capacitance ESD Suppressor Resistive Product Solutions Features: • • • • • • • • Very quick response time (< 1 nS) ESDU series has ultra-low capacitance < 0.05 pF Lower cost ESD series has capacitance < 0.2 pF Ultra-low leakage current (< 1 nA) No signal distortion 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Applications: • • • • High speed data ports (USB 2.0, IEEE1394) Notebook PC’s, cell phones, PDA’s Digital cameras, printers, scanners Plasma display panels, LCD TVs, HDTV’s Electrical Specifications Type Package Size Continuous Operating Voltage (VDC) (Max) ESD Capability (1) Trigger Voltage (V) (Typical)(2) ESD(U)02A3V3R17V 0402 ESD(U)03A3V3R17V 0603 3.3 ESD(U)02A3V3R25V 0402 ESD(U)03A3V3R25V 0603 ESD(U)02A5V5R17V 0402 ESD(U)03A5V5R17V 0603 Direct Discharge: 8 kV 5.5 Air Discharge: 15 kV ESD(U)02A5V5R25V 0402 ESD(U)03A5V5R25V 0603 ESD(U)02A12VR25V 0402 12 ESD(U)03A12VR25V 0603 ESD(U)02A24VR25V 0402 24 ESD(U)03A24VR25V 0603 1. ESD capability meets the requirements of IEC 61000-4-2. 2. Trigger measurement made using Transmission Line Pulse Method. 3. Capacitance measured from 1 MHz - 1.8 GHz. 4. Under IEC 61000-4-2 level 4 (8 kV contact discharge, 15 kV air discharge). Clamping Voltage (V) (Typical) 150 17 250 25 150 17 250 25 250 25 Capacitance (3) Leakage Current (Typical) Response Time ESD Pulse Withstand (Typical) (4) < 1 nA < 1 nS > 1000 pulses ESD Series < 0.2 pF ESDU Series < 0.05 pF Mechanical Specifications Type / Code ESD(U)02 (0402) ESD(U)03 (0603) L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 Rev Date: 12/12/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. H Body Height 0.014 ± 0.002 0.35 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 1 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 b Bottom Termination 0.010 ± 0.004 0.25 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 Unit inches mm inches mm www.seielect.com marketing@seielect.com ESD/ESDU Series Stackpole Electronics, Inc. Low and Ultra Low Capacitance ESD Suppressor Resistive Product Solutions Performance Characteristics Test Test Method Test Specification Test Condition Operating Temperature -55 to 125°C Full Load Voltage 1000 hours at 25°C Bending 3 mm deflection Leakage Current < 1 uA Resistance to Solder Heat MIL-STD-202 Method 210 260 ± 5°C for 10 ± 1 seconds Moisture Resistance MIL-STD-883 Method 1004.7 85% RH, 85°C for 1000 hours Thermal Shock MIL-STD-202 Method 107 5 cycles from -55 to 125°C MIL-STD-202 Method 208 245 ± 5°C, 2 ± 0.5 seconds dwell, Sn96.5 / Ag3.0 / Cu0.5 solder Solderability 95% coverage RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series ESD(U) Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Low and Ultra-Low Capacitance ESD Suppressor SMD YES 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 12/12/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com ESD/ESDU Series Stackpole Electronics, Inc. Low and Ultra Low Capacitance ESD Suppressor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order E S D 0 Product Series Size Description Low Capacitance ESD < 0.2 pF Ultra Low Capacitance ESDU < 0.05 pF Code Size 02 0402 03 0603 Code 2 A 3 Tolerance Code A Description Suitable for IEC 61000-4-2 Rev Date: 12/12/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 V Operating Voltage Code V 3V3 3.3 5V5 5.5 12V 12 24V 24 3 R 1 7 Packaging Code Description Sizes Quantity 0402 10000 R Tape & Reel 0603 5000 V Clamping Voltage Code V 17 V 17 25 V 25 www.seielect.com marketing@seielect.com
ESDU02A5V5R17V 价格&库存
很抱歉,暂时无法提供与“ESDU02A5V5R17V”相匹配的价格&库存,您可以联系我们找货
ESDU02A5V5R17V
  • 10000+0.6995010000+0.09061
  • 20000+0.6411220000+0.08305
  • 30000+0.6113730000+0.07920
  • 50000+0.5779550000+0.07487
  • 70000+0.5581570000+0.07230
  • 100000+0.53892100000+0.06981
库存:180007
ESDU02A5V5R17V
  • 1+3.882041+0.50286
  • 10+2.3633510+0.30614
  • 100+1.48605100+0.19250
  • 500+1.10702500+0.14340
  • 1000+0.984431000+0.12752
  • 2000+0.880982000+0.11412
  • 5000+0.768875000+0.09960
库存:180007
ESDU02A5V5R17V
    ESDU02A5V5R17V
      ESDU02A5V5R17V
