Effective April 2024
Supersedes December 2020
Technical Data 4377
CB61F
Fast-acting surface mount Brick™ fuses
Applications
Primary circuit protection
Product features
Power supplies
Servers
Medical equipment
White goods
Battery chargers
Consumer electronics
Test equipment
Battery pack protection
Fast-acting
2410 (6125 metric) compact footprint
Designed to UL 248
Agency information
High interrupting ratings
Current ratings from 2 A to 40 A
UL Listed cULus: File E19180, Guide
JDYX (2 A - 15 A)
Reflow and wave solder compatible
Wire-in-air design
UL Recognized cURus: File E19180, Guide
JDYX2 (20 A - 40 A)
Moisture sensitivity level (MSL): 1
CQC: CQC09012040316 (2 A - 6.3 A & 8 A - 10 A)
Environmental compliance
HALOGEN
Pb
HF
FREE
Ordering code
The ordering code is the part number replacing the
“.” with a “-” plus adding the packaging suffix.
CB61F 6-3A
Product code
Ampere rating
Packaging suffix
-TR1 1000 fuses on a 7” diameter tape and
reel
-TR2 5000 fuses on a 13” diameter tape and
reel (2 A to 15 A only)
CB61F
Technical Data 4377
Electrical characteristics
Amp Rating
% of Amp Rating
Opening Time
2 A – 40 A
100%
4 hours minimum
2 A – 15 A
200%
5 seconds maximum
20 A – 40 A
200%
60 seconds maximum
Product specifications
Current
rating
(A)
Voltage
rating
(Vac)
Voltage
rating
(Vdc)
Interrupting rating1,2
(A) @ rated voltage
(Vac)
(Vdc)
Typical DC
cold
resistance3
(mΩ)
Typical
melting4
I²t (A2s)
Typical
voltage
drop5 (mV)
Part
marking
CB61F2A
2.0
125
125
100
300
39
0.85
100
2
x
x
CB61F3A
3.0
125
125
100
300
25
2.08
100
3
x
x
CB61F4A
4.0
125
125
100
300
17
4.4
93
4
x
x
CB61F5A
5.0
125
125
100
300
13
7.7
90
5
x
x
CB61F6.3A
6.3
125
125
100
300
10
13.7
90
6.3
x
x
CB61F7A
7.0
125
125
100
300
9
15.6
85
7
x
CB61F8A
8.0
125
125
100
300
8
19.5
90
8
x
x
CB61F10A
10
125
125
100
300
6
36
90
10
x
x
CB61F12A
12
125
125
50
200
5
40
90
12
x
CB61F15A
15
125
125
50
200
4
56
85
15
x
CB61F20A
500
2.3
210
60
x
CB61F25A
25
72
500
1.7
400
55
25
x
CB61F30A
30
72
500
1.2
900
50
30
x
CB61F40A
40
63
500
0.9
1600
50
40
x
Part Number
1.
2.
3.
4.
5.
AC Interrupting rating: Measured at rated voltage, 100% power factor
DC Interrupting rating: Measured at rated voltage, time constant of less than 50 microseconds, battery source
Typical DC cold resistance: Measured at 10% of rated current
Typical Pre-arcing I2t are measured at 10In Current
Typical voltage drop: Measured at rated current after temperature stabilizes
Dimensions–mm
2 A to 15 A
Recommended pad layout
20 A to 40 A
2
www.eaton.com/electronics
Agency approval
cULus
cURus
CQC
Technical Data 4377
CB61F
Time current curve
2 A to 15 A
20 A to 40 A
Temperature derating curve
General specifications
Operating temperature: -55 °C to +125 °C (with derating)
Storage temperature: -55 °C to +125 °C
Thermal shock: 2 A to 15 A - MIL-STD-202, Method 107G, -65 °C/+125 °C, number of cycles :10
20 A to 40 A - MIL-STD-202, Method 107G -55 °C/+125 °C, number of cycles: 100
Bias humidity: 2 A to 15 A - MIL-STD-202, Method 103 +85 °C/85%RH. ,100 hours
20 A to 40 A - MIL-STD-202, Method 103 +85 °C/85%RH. ,1000 hours
Mechanical shock: 2 A to 40 A - MIL-STD-202G, Method 213B, Test condition C, 100 g’s peak for 6 ms; Half-sine waveform
Mechanical vibration: 2 A to 15 A - MIL-STD-202G, Method 201, Test condition A (10 - 55 Hz, 0.06 inch, 2 hours each of 3 mutually perpendicular
direction, total 6 hours), high Freguency: 20 g’s for 20 min., 12 cycles each of 3orientations. ,10 - 2000 Hz.10 to 55 Hz, 0.06 inch, total excursion
20 A to 40 A - MIL-STD-202G, Method 201, 2 hours each of 3 orientations. Test from 10 -5 5 Hz in 1 minute
Resistance to solder heat: 2 A to 40 A - MIL-STD-202G, Method 210F , condition D (+260 °C, 10s)
3
CB61F
Technical Data 4377
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Reference EN 61760-1:2006
Profile feature
Standard SnPb solder
Lead (Pb) free solder
• Temperature min. (Tsmin)
100 °C
100 °C
• Temperature typ. (Tstyp)
120 °C
120 °C
• Temperature max. (Tsmax)
130 °C
130 °C
• Time (Tsmin to Tsmax) (ts)
70 seconds
70 seconds
D preheat to max Temperature
150 °C max.
150 °C max.
Peak temperature (TP)*
235 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Preheat
Manual solder
+350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended
4
CB61F
Technical Data 4377
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“CB61F10A-TR1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+6.251941000+0.80230
- 国内价格
- 1+6.92280
- 10+6.77160
- 30+6.66360
