Effective October 2017
Supersedes May 2017
Technical Data 3001
3216FF
HALOGEN
Fast-acting Chip™ surface mount fuse
HF
FREE
Pb
Environmental data
Product features
AEC-Q200 qualified (250 mA to 7 A)
Fast-acting surface mount fuse
Ratings up to 30 amps
Excellent temperature and cycling characteristics
Compatible with reflow and wave solder
Agency information
• UL Recognition Guide JDYX2 & File E19180.
• CSA Component Acceptance: 053787 C 000 &
Class No: 1422 30.
• cURus Recognition File: E19180, Guide JDYX2/
JDYX8
• Thermal Shock: MIL-STD-202, Method 107,
Test Condition B (-65 °C to +125 °C)
• Vibration: MIL-STD-202, Method 204,
Test Condition C (55 Hz - 2 kHz, 10 G)
• Moisture Resistance: MIL-STD-202, Method
106,10 day cycle
• Solderability: ANSI/J-STD-002, Test B
• Additional resistance to solder heat test: MILSTD-202G Method 210F Condition A
• Operating Temperature: -55 ºC to +125 ºC
• AEC-Q200 qualified (250 mA to 7 A)
Ordering
• Specify packaging and product code (i.e.,
TR/3216FF250-R)
Amp Rating
250mA - 30A
1.25A - 3A
250mA - 3A
4A - 7A
10A - 30A
Soldering method
Electrical Characteristics
% of Amp Rating
100%
200%
250%
350%
350%
Opening Time
4 Hrs. Min.
60 Sec. Max.
5 Sec. Max.
1 Sec. Max.
5 Sec. Max.
• Wave Immersion: 260 °C, 10 sec max.
• Infrared Reflow: 260 °C, 30 sec max.
Part
Number
3216FF250-R
3216FF375-R
3216FF500-R
3216FF750-R
3216FF1-R
3216FF1.25-R
3216FF1.5-R
3216FF2-R
3216FF2.5-R
3216FF3-R
3216FF4-R
3216FF4.5-R
3216FF5-R
3216FF6.5-R
3216FF7-R
3216FF10-R
3216FF12-R
3216FF15-R
3216FF20-R
3216FF25-R
3216FF30-R
Vac
32
32
32
32
32
32
32
32
32
32
32
32
32
32
32
Volt Ratings
Vdc
63
63
63
63
63
63
63
63
63
63
32
32
32
32
32
24
24
24
24
24
24
Specifications
Interrupting Rating* Typical DC Cold
(amps) AC/DC
Resistance (Ω)**
50
3.5000
50
1.7500
50
0.9800
50
0.5400
50
0.2190
50
0.1700
50
0.1190
50
0.0660
50
0.0460
50
0.0360
50
0.0180
50
0.0160
50
0.0140
50
0.0086
50
0.0070
150
0.0045
150
0.0039
150
0.0031
150
0.0018
250
0.0014
300
0.0012
Typical Melt
I2t (A2S) DC***
0.00038
0.00077
0.00190
0.0053
0.030
0.046
0.093
0.126
0.260
0.275
0.337
0.405
0.534
2.294
3.623
2.0
7.0
25.5
48.6
32.0
43.0
Typical Voltage
Drop (V)†
1.40
0.73
0.66
0.63
0.20
0.18
0.18
0.16
0.14
0.13
0.11
0.10
0.09
0.076
0.078
0.062
0.070
0.066
0.060
0.057
0.068
UR
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Agency Approvals
CSA
cURus
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
*AC Interrupting Rating measured at rated voltage with a unity power factor; DC Interrupting Rating measured at rated voltage, time constant of less than 50 microseconds, battery source
**Typical DC Cold Resistance measured at 10% of rated current
***Typical Melting I2t measured with a battery bank at rated DC voltage, 10x-rated current, not to exceed IR, time constant of calibrated circuit less than 50 microseconds (6.5A - 30A measured at interrupting
rating) †Typical Voltage Drop measured at rated current after temperature stabilizes. It is recommended that fuses be mounted with ceramic (white) side facing up.
Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with further derating required at elevated ambient temperatures.
3216FF
Technical Data 3001
Effective May 2017
25A
30A
15A
Time in Seconds
20A
Recommended Pad Layout - mm (in)
10A
12A
5A
1.5A
2A
2.5A
3A
4A
4.5A
0.375A
0.25A
Drawing Not to Scale
0.75A
1A
0.5A
6.5A
7A
Time-Current Curve
Dimension - mm/inches
Current in Amps
Packaging
Packaging Code Prefix
TR
Description
3000 fuses on 8mm tape-and-reel on a 7 inch (178mm) reel per EIA Standard RS481
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 3001 BU-SB11302
October 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“TR/3216FF15-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+4.99359
- 30000+2.95021
- 国内价格
- 1+13.71600
- 10+13.41360
- 30+13.20840
- 国内价格 香港价格
- 1+16.328871+2.12270
- 5+13.500675+1.75505
- 10+12.4601110+1.61978
- 50+10.3365050+1.34371
- 100+9.53638100+1.23970
- 250+8.57055250+1.11415
- 500+7.90217500+1.02726
- 1000+7.282901000+0.94676
