Technical Data 2009
Effective December 2015
Supersedes October 2014
BUSSMANN
SERIES
ATC
Blade fuses
Features and benefits:
Product description:
A range of UL® Recognized fast-acting ATC
blade fuses for automotive and low-voltage
control circuits.
Featuring the same form, fit, and electrical
and performance characteristics, ATC fuses
are available in a variety of housing materials
specific to orderable catalog numbers to meet
application needs.
Industry standard color coding for quick
identification of amp rating
Tin-plated zinc terminals for corrosion
resistance and enhanced conductivity
UL Recognized for use in low voltage control
circuits
Wide -40°C to +100°C operating temperature
range meets the needs of extreme
environments
Lead free, halogen free and RoHS complaint
Test points on specific part/package numbers
may speed up circuit troubleshooting
ATC blade fuses
Technical Data 2009
Catalog symbol: ATC
Electrical characteristics @23°C* for all available catalog
numbers
Applications:
Automotive and low-voltage control circuits.
% of fuse amp rating Min
110
135
160
200
350
600
Ratings:
Volts
Amps
Interrupting rating
32V
1-40A
* Fuse derating with change in ambient temperature = -0.15% / 1°C
1kA
** 135% Operating time of less than 4 amps.
Recommended fuse panels, holders and fuseclips
Agency information:
UL Recognized File E56412, Guide JFHR2, UL 248-1 (1-40A).
ISO 8820-3 / SAE J1284 / JASO 612 (1-40A).
SAE J1171 (Ignition protection) see catalog number tables for
specific orderable product.
RoHS compliant
HHG
Tin-plated zinc
Element
HHR
Tin-plated zinc
Housing (see catalog number tables for specific housing
materials)
Housing flammability rating
HHC
HHF
Terminals
Part no.
15600-_-20
HHD
Materials:
Operating time (sec)
Max
100 Hrs
0.75
120 (240**)
0.25
50
0.15
5
0.04
0.5
0.02
0.1
UL 94
Environmental:
BP/HHS-RP
BP/HHA-RP
ATC-FHID
1A5600*
1A5780*
Description
ATC Fuse panel in 4- to 20-poles
Yellow, water resistant in-line
fuse holder
Black, heavy-duty in-line fuse
holder
Black, in-line fuse holder w/
cover
holder w/cover
Heavy-duty, water resistant inline fuse holder
Self-stripping in-line fuse holder
Add-A-Fuse
Illuminating in-line fuse holder
PCB Fuseclip
PCB Fuseclip
Max Lead wire
amps length/size
20A
20A
2x4”/#16
30A
2x4”/#12
20A
2x4”/#14
30A
2x4”/#12
30A
2x5”/#12
20A
10A
20A
20A
15A
#18 to #14
N/A
2x6”/#16
* See Data Sheet No. 2131 for details.
Operating temperature range -40°C to 100°C,
95% RH non-condensing.
Storage temperature range -5°C to 35°C or lower,
85% RH non-condensing.
Dimensions - mm
Basic part numbers*
19.10
Part number
(amp)
ATC-1
ATC-2
ATC-3
ATC-4
ATC-5
ATC-7½
ATC-10
Color code
Black
Gray
Violet
Pink
Tan
Brown
Red
Part number
(amp)
ATC-15
ATC-20
ATC-25
ATC-30
ATC-35
ATC-40
Color code
Blue
Yellow
Clear
Green
Blue/Green
Orange
Test points on select constructions.
See catalog number tables for details.
5.10
4.0
2.29
* See catalog number tables on page four for specific construction, housing
material and package availability.
18.70
6.42
0.65
4.0
3.65
14.5
Dimensions shown are basic for all ampacities, constructions and housing materials.
2
Eaton.com/bussmannseries
ATC blade fuses
Technical Data 2009
Effective October 2015
Time in seconds
Time-current characteristic curves — average melt - for all fuse constructions/housing materials
Current in amps
3
ATC blade fuses
Technical Data 2009
ATC fuse construction and housing material availability by catalog number
Table 1. ATC fuse catalog number availability for open body housing without test points*
Reload
ATC-5RLD
ATC-7½RLD
ATC-10RLD
ATC-15RLD
ATC-20RLD
ATC-25RLD
ATC-30RLD
Bulk packs
BK/ATC-5
BK/ATC-7½
BK/ATC-10
BK/ATC-15
BK/ATC-20
BK/ATC-25
BK/ATC-30
Blister packs
BP/ATC-5-RP
BP/ATC-7½-RP
BP/ATC-10-RP
BP/ATC-15-RP
BP/ATC-20-RP
BP/ATC-25-RP
BP/ATC-30-RP
Assortments/kits/trays
BP/ATC-A5-RP (fuse assortment)
BP/ATC-AH8-RPP (fuse emergency kit)
BP/ATC-AL8-RP (low amp assortment)
DIA-1 (diagnostic kit)
NO.44 (fuse emergancy kit)
NO.80 (bulk assortment)
NO.95BK (ATC/ATM bulk assortment)
NO.53 (ATC/MAX fuse emergency kit)
NO.160BK (bulk assortment)
NO.225 (tilt bin assortment)
Housing material
Nylon
Nylon
Nylon
Nylon
Nylon
Nylon
Nylon
Nylon
Nylon
Nylon
* For specific quantities and amp ratings, see consumer aftermarket product catalog No. 5084.
Table 2. ATC fuse catalog number availability for closed body housing with test points and SAE J1171 ignition protected
Reload
ATC-3RLD
ATC-4RLD
Bulk packs*
BK/ATC-1
BK/ATC-2
BK/ATC-3
BK/ATC-4
BK/ATC-5M
BK/ATC-71/2M
BK/ATC-10M
BK/ATC-15M
BK-ATC-20M
BK-ATC-25M
BK-ATC-30M
BK-ATC-35
BK-ATC-40
Blister packs
BP/ATC-1-RP
BP/ATC-2-RP
BP/ATC-3-RP
BP/ATC-4-RP
BP/ATC-40-RP
5-in tins**
ATC-1
ATC-2
ATC-3
ATC-4
ATC-5
ATC-71/2
ATC-10
ATC-15
ATC-20
ATC-25
ATC-30
ATC-35
ATC-40
Value packs
VP/ATC-5-RP
VP/ATC-7-1/2-RP
VP/ATC-10-RP
VP/ATC-15-RP
VP/ATC-20-RP
VP/ATC-25-RP
VP/ATC-30-RP
Assortments
CDY10TRY-ATC (fuse
tray)***
NO.290†
Housing material
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polycarbonate
Polysulfone
Polyethersulfone
* 2000 fuses per pack.
** 5 fuses per tin.
*** Contains (5 each) – ATC 3, 4, 5,and 7-1/2.
(10 each) – ATC 10, 15, 20, 25, 30, 35 and 40A.
† Contains one 5-in tin each of ATC 3, 4, 5, 7 1/2, 10, 15, 20, 25, 30, 35 and 40A.
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 2009 – BU-SB13997
December 2015
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK/ATC-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+23.496691+3.04945
- 5+19.521155+2.53349
- 10+18.0031010+2.33648
- 50+14.9390350+1.93882
- 100+13.78234100+1.78870
- 250+12.38320250+1.60712
- 500+11.41574500+1.48156
- 1000+10.518761000+1.36515
- 5000+8.678035000+1.12625
- 国内价格
- 1+2.21994
- 200+0.85914
- 500+0.82890
- 1000+0.81400
- 国内价格
- 1+9.25791
- 50+8.90383
- 250+8.48728
