5 x 20mm Fuses
S501 Series, Fast-Acting, Ceramic Tube
Description
• Fast-acting high breaking capacity
• Optional axial leads available
• 5 x 20mm physical size
• Ceramic tube with silver-plated (50mA-400mA) and
nickel-plated (500mA-10A) endcaps.
• Designed to IEC 60127-2
In
50mA-4A
5A-6.3A
8A-10A
Electrical Characteristics
1.5 In 2.1 In
2.75 In
4 In
min
max
min
max
min
max
60 min 30 min 10 ms 2 sec 3 ms 300 ms
60 min 30 min 10 ms 3 sec 3 ms 300 ms
30 min 30 min 40 ms 20 sec 10 ms
1s
Agency Information
cURus: File E19180, Guide JDYX2, JDYX8
CSA Component Acceptance: File 53787
SEMKO Approval: File 413779
VDE Approval: File 40015517
IMQ Approval: File EB405
CCC Approval: File 2005010207155691
BSI Approval: File KM55676
10 In
max
20 ms
20 ms
30 ms
Dimensions - mm
Drawing Not to Scale
Ordering
• Specify packaging, product, and option code
• Ratings above 6.3A have a 0.8mm diameter lead
• With TR2 packaging code, lead wire length is 19.05mm
Specifications
Product
Code
S501-50-R
S501-63-R
S501-80-R
S501-100-R
S501-125-R
S501-160-R
S501-200-R
S501-250-R
S501-315-R
S501-400-R
S501-500-R
S501-630-R
S501-800-R
S501-1-R
S501-1.25-R
S501-1.6-R
S501-2-R
S501-2.5-R
S501-3.15-R
S501-4-R
S501-5-R
S501-6.3-R
S501-8-R
S501-10-R
Voltage Interrupting Rating at
Typical DC
Typical
Typical
Agency Approvals
Rating Rated Voltage (50Hz) Cold Resistance Melting I2t Voltage IMQ VDE BSI SEMKO cURus CCC MITI/
Vac
Vac
(Ω)*
(amps) Drop (mV)†
JET
250
1500
157.5
0.0017
9000
X
X
X
X
X
X
250
1500
39.0
0.0005
3300
X
X
250
1500
27.9
0.0011
2600
X
250
1500
20.0
0.0018
2300
X
250
1500
12.3
0.0037
1900
X
250
1500
8.5
0.008
1600
X
X
X
X
X
X
250
1500
6.0
0.02
1350
X
X
X
X
X
X
250
1500
4.4
0.027
1300
X
X
X
X
X
X
250
1500
3.3
0.01
1400
X
X
X
X
X
X
250
1500
2.2
0.018
1200
X
250
1500
0.460
0.038
1050
X
X
X
X
X
X
250
1500
0.340
0.064
1200
X
250
1500
0.245
0.097
490
X
X
X
X
X
X
250
1500
0.231
0.146**
330
X
X
X
X
X
250
1500
0.176
0.313**
297
X
X
X
X
250
1500
0.113
0.748**
239
X
X
X
X
X
250
1500
0.073
2.0
205
X
X
X
X
X
X
X
250
1500
0.053
3.9
190
X
X
X
X
X
X
X
250
1500
0.037
8.1
160
X
X
X
X
X
X
X
250
1500
0.027
14
160
X
X
X
X
X
X
X
250
1500
0.019
25
155
X
X
X
X
X
X
X
250
1500
0.014
48
150
X
X
X
X
X
X
250
1500
0.009
N/A
N/A
X
X
X
X
X
250
1500
0.008
N/A
N/A
X
X
X
X
X
DC Cold Resistance (measured at
很抱歉,暂时无法提供与“BK/S501-2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.43165
- 200+0.55404
- 500+0.53460
- 1000+0.52499
- 国内价格 香港价格
- 100+32.74088100+4.22620
- 国内价格
- 15+44.47071
- 60+37.42166
- 100+31.43661
- 1000+9.29798
