Effective June 2023
Supersedes November 2021
Technical Data 4406
S505H
5 mm x 20 mm 400 Vdc/500-600 Vac time-delay fuse
Applications
Product features
400 Vdc/500-600 Vac rating
Time-delay, high breaking capacity
5 mm x 20 mm physical size
Ceramic tube with plated end cap
construction
Designed to IEC 60127-2, Standard, Sheet 5
Optional axial leads available
Fuse accesories guide (holders, clips)
Ordering part number
The ordering code is the part number replacing
the “.” with a “-”
Power supplies - adapters
Desktops/notebooks
TVs / Displays
Set top boxes
Lighting ballasts
Battery chargers
Printers
Game systems
Air conditioners
Agency information
S505H-XXX-R (Cartridge)
BK-S505H-V-6-3-R
cURus Recognition file:
E56412, Guide JFHR2,JFHR8, (500 mA - 10 A);
E19180, Guide JDYX2 and JDYX8, (12 A - 20 A)
CCC Approval: 500 mA - 10 A, Cert. No.:
2020970207000249
TUV Approval: 2 A - 10 A, Cert. No.: R50297821
PSE Approval: 1 A - 5 A, Cert. No.: JET164131003-1025; 6.3 A - 10 A JET1641-31003-1023
KC Approval: SU05011-21001A (1 A - 2.5 A),
SU05011-21002A (3.15 A - 6.3 A), SU0501121003A (8 A -10 A), SU05011-21004A (500 mA
- 800 mA)
S505H-V-XXX-R (Axial leads)
Packaging prefix
Family name
Option code (V = axial leaded)
Ampere rating
RoHS compliance
Packaging prefix
Blank: 5 cartridge parts in a 5 inch tin, 4 axial
lead parts in a 5 inch tin) (Values < 12 A only)
BK-: 100 parts packed in a cardboard carton
(axial leaded only)
BK1-: 1000 parts in a poly bag (cartridge version only)
TR2- 1500 parts on a reel (axial lead V option
only, values < 12 A only)
No.:JET164131003-1026; 6.3 A - 10 A, Cert.
No: JET1641-31003-1024
2020970207000249
TUV Approval: 500 mA-10 A, Cert. No.:
R50297821
- 800 mA)
Option code
-V : (Axial leads – copper tinned wire with
nickel plated brass end caps)
Environmental compliance
HALOGEN
Pb HF
FREE
S505H
Technical Data 4406
Effective June 2023
Electrical characteristics
Amp Rating
1.5 In
minimum
minutes
2.1 In
maximum
minutes
2.75 In
minimum
ms
maximum
seconds
4.0 In
minimum
ms
maximum
seconds
10 In
mimimum
ms
maximum
ms
500 mA - 1 A
60
30
250
80
50
5
5
150
1 A - 3.15 A
60
30
750
80
95
5
10
150
4 A -6.3 A
60
30
750
80
150
5
10
150
8 A -10 A
30
30
750
80
150
5
10
150
12 A - 20 A
30*
30
750
80
150
8
10
150
* 1.5 In rating for cartridge version only
Product specifications
Part number
Current
rating
(A)
Voltage rating1
(Vac)
(Vdc)
Interrupting rating @ rated voltage
(A) @
(A) @
(A) @
250 Vac2 600 Vac3
400 Vdc4
Typical DC
cold resistance5
(Ω)
Typical
voltage drop6
(mV)
Typical
melting7
I2t (A2s)
S505H(-V)-500-R
0.5
600
400
1500
100
1500
0.507
295
S505H(-V)-800-R
0.8
600
400
1500
100
1500
0.237
189
S505H(-V)-1-R
1
600
400
1500
100
1500
0.157
S505H(-V)-1.25-R
1.25
600
400
1500
100
1500
0.108
S505H(-V)-1.6-R
1.6
600
400
1500
100
1500
S505H(-V)-2-R
2
600
400
1500
100
1500
S505H(-V)-2.5-R
2.5
600
400
1500
100
1500
Agency approvals
250 Vac
Tuv
CCC
PSE/JET
cURus9
0.188
8
x
x
x
0.632
x8
x
x
176
1.28
8
x
x
x
x
150
2.22
x8
x
x
x
0.070
125
6.78
x
x
x
x
0.055
128
11.44
x
x
x
x
0.040
126
24.23
x
x
x
x
8
S505H(-V)-3.15-R
3.15
600
400
1500
100
1500
0.031
121
43.55
x
x
x
x
S505H(-V)-4-R
4
600
400
1500
100
1500
0.019
90
38.45
x
x
x
x
S505H(-V)-5-R
5
600
400
1500
100
1500
0.015
89
71.30
x
x
x
x
S505H(-V)-6.3-R
6.3
500
400
1500
100 @ 500 Vac
1500
0.011
80
111.4
x
x
x
x
S505H(-V)-8-R
8
500
400
1500
100 @ 500 Vac
1500
0.007
76
228.2
x
x
x
x
S505H(-V)-10-R
10
500
400
1500
100 @ 500 Vac
1500
0.006
72
349.5
x
x
x
x
S505H(-V)-12-R
12
500
400
na
200 @ 500 Vac
300
0.00545
80
550
x
S505H(-V)-15-R
15
500
400
na
200 @ 500 Vac
300
0.004
75
900
x
S505H(-V)-16-R
16
500
400
na
200 @ 500 Vac
300
0.0037
68
1100
x
S505H(-V)-20-R
na
na
200 @ 500 Vac
na
0.00325
75
1500
x
1. Voltage rating: based on the interrupting rating test according to UL.
2. Interrupting rating of 250 Vac/1500 A is tested by all agency approvals, test
condition is 250 Vac, PF: 0.7 - 0.8.
3. Interrupting rating of Vac is tested with, PF:1.0 (500 mA - 5 A @ 600 Vac, 6.3 A - 20 A @ 500
Vac)
4. Interrupting rating of Vdc is tested under capacitor bank for 500 mA to 10A; Vdc interrupting
rating for 12 A– 20 A is tested under power supply with time constant less than 1 ms.
2
www.eaton.com/electronics
5. Typical cold resistance measured at
很抱歉,暂时无法提供与“BK1-S505H-2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 150+6.34778
- 400+6.16642
- 750+6.06969
