Effective June 2017
Supersedes July 2009
Technical Data 4332
S506
5 mm x 20 mm Time-delay glass tube fuses
Agency information
Product features
Time-delay, low breaking capacity
Optional axial leads available
5 x 20mm physical size
Glass tube, nickel-plated brass endcap construction
Designed to IEC 60127-2/3 (32mA-10A) &
extensions:12.5A-15A
• UL Recognized Card: Guide JDYX2, File E19180
• CSA Component Acceptance: Class number 1422-30&90
File 053787
• cURus Recognition: Guide JDYX8, File E19180
• SEMKO Approval: File 1518843, 1410180
• VDE Approval: File 40011926
• BSI Approval: File KM55676
• IMQ Approval: File E1921
• PSE/JET: File JET1641-31003-1019, JET1641-31003-1020
• CCC Approval: File 2005010207155693, 2002010207011294
• Ordering information
• Specify product code
• Insert packaging code prefix before part number. E.g. BK/
S506-1-R
• Ratings above 4A have a 0.81mm diameter lead
S506 Electrical Characteristics
2.1 In
2.75 In
4 In
10 In
In
max min
max min
max min
max
32mA-100mA 2 min 200 ms 10 sec 40 ms 3 sec 10 ms 300 ms
125mA-6.3A 2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms
8A-15A
Product
Code
S506-32-R
S506-40-R
S506-50-R
S506-63-R
S506-80-R
S506-100-R
S506-125-R
S506-160-R
S506-200-R
S506-250-R
S506-315-R
S506-400-R
S506-500-R
S506-630-R
S506-800-R
S506-1-R
S506-1.25-R
S506-1.6-R
S506-2-R
S506-2.5-R
S506-3.15-R
S506-4-R
S506-5-R
S506-6.3-R
S506-8-R
S506-10-R
S506-12.5-R
S506-15-R
Voltage Interrupting Rating
(amps) at Rated
Rating
Voltage (50Hz) Vac
Vac
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
35
250
40
250
50
250
63
250
80
250
100
250
125
250
125
Typical DC
Cold Resistance
(Ω)*
21.0
13.90
9.24
6.96
4.42
2.80
1.97
1.27
1.00
0.640
0.450
0.31
0.183
0.186
0.129
0.0757
0.060
0.0425
0.03325
0.0255
0.0185
0.0139
0.00985
0.0071
0.007
0.005
0.004
0.004
Typical
Typical
Melting I2t
Voltage
(amps)
Drop (mV)‡
0.0051
1050
0.0072
920
0.0095
800
0.021
760
0.038
580
0.045
490
0.063
390
0.093
320
0.114
340
0.265
270
0.621
250
0.872
210
0.827
140
1.33
150
2.78
75
6.45
87.5
10.05
86
21.7
82
31.6
77
59.4
72.5
96.4
68.5
71.8
67
142.5
60.5
237.6
54
255.8
55
450
54
1019.5
45
1091.7
65.5
* DC Cold Resistance (measured at
很抱歉,暂时无法提供与“BK/S506-250-R”相匹配的价格&库存,您可以联系我们找货
