C310T-SC-2-R-TR1
C310T-SC-2-R-TR1
    EATON(伊顿)
    插件,D3.6xL10mm
    一次性保险丝(熔断) 2A 250V
C310T-SC-2-R-TR1 数据手册
Effective December 2019 Supersedes March 2016 Technical Data 10404 C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses Applications HALOGEN Pb HF FREE Primary circuit protection: • Power supplies • LED and general lighting • Consumer electronics • Desktop, laptop and notebook • Test equipment Agency information Product features • Time-delay • Designed to IEC60127-3 • Nickel-plated brass single end cap construction • 3.6 mm x 10 mm compact design utilizes less board space • cURus Recognition file number: E19180, Guide JDYX2/JDYX8 • CCC: 2019010207248211 • KC-Mark: File SU05011-13001, SU05030-13006 • TUV: J50247281, J50235242 • VDE: 40036716 Ordering • Use ordering number (see page 6 for details) Packaging suffixes • -TR1 (1500 parts per 10” diameter reel, tape width 60 mm) • -TR2 (1500 parts per 10” diameter reel, tape width 52 mm) C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses  Technical Data 10404 Effective December 2019 Electrical characteristics ln 1.5ln min minute 2.1ln max minute 2.75ln min ms max s 4ln min ms max s 10ln min ms max ms 2A- 6.3A 60 2 400 10 150 3 20 150 ln 1.5ln min minute 3ln min ms max s 10ln min ms max ms 8A 60 400 10 20 150 Part marking: engraved on end cap 2nd end cURus Product specifications Part number1 Current rating (A) Voltage rating (Vac) Interrupting rating at rated voltage (A) Typical DC cold resistance (mΩ ) Typical melting l2t (A2s) Maximum voltage drop (mV) Part marking: engraved on end cap 1st end KC CCC TUV VDE C310T-SC-2-R 2 250 35 26.5 12 100 T2A L 250V BUSS C310T-SC x x x x x C310T-SC-2.5-R 2.5 250 35 19.5 18.5 100 T2.5A L 250V BUSS C310T-SC x x x x x C310T-SC-3.15-R 3.15 250 35 14.7 38 100 T3.15A L 250V BUSS C310T-SC x x x x x C310T-SC-4-R 4 250 40 10.6 58 100 T4A L 250V BUSS C310T-SC x x x x x C310T-SC-5-R 5 250 50 7.3 57.5 100 T5A L 250V BUSS C310T-SC x x x x x C310T-SC-6.3-R 6.3 250 63 7.1 123 100 T6.3A L 250V BUSS C310T-SC x x x x x C310T-SC-8-R 8 250 80 3.7 200 80 T8A L 250V BUSS C310T-SC x 1. Part Number Definition: C310T-SCxxx-R C310T = Product code SC = Single cap xxx = Ampere rating -R suffix = RoHS compliant Dimensions–mm 2 www.eaton.com/electronics C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses Technical Data 10404 Effective December 2019  Time (s) Time vs. current curve Current (A) www.eaton.com/electronics 3 Technical Data 10404 Effective December 2019 C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses  l2t (A2s) I2t vs. current curve Current (A) 4 www.eaton.com/electronics C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses Technical Data 10404 Effective December 2019  l2t (A2s) I2t vs. time curve Time (s) www.eaton.com/electronics 5 C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses  Technical Data 10404 Effective December 2019 Percentage of Rating Temperature derating curve Temperature in Degrees C General specifications Operating temperature: -55 °C to +125 °C (with derating) Thermal shock: MIL-STD- 202G, Method 107G, test condition B (5 cycles -65 °C to +125 °C) Vibration: MIL-STD- 202G, Method 201A Humidity: MIL-STD- 202G, Method 103B, test condition A Salt spray: MIL-STD- 202G, Method 101D, Test condition B Ordering codes The ordering code is the part number replacing the “.” with a “-” plus adding the packaging suffix. Packaging suffixes • -TR1 (1500 parts per 10” diameter reel, tape width 60 mm) • -TR2 (1500 parts per 10” diameter reel, tape width 52 mm) Ordering codes Part number -TR1 option -TR2 option C310T-SC-2-R C310T-SC-2-R-TR1 C310T-SC-2-R-TR2 C310T-SC-2.5-R C310T-SC-2-5-R-TR1 C310T-SC-2-5-R-TR2 C310T-SC-3.15-R C310T-SC-3-15-R-TR1 C310T-SC-3-15-R-TR2 C310T-SC-4-R C310T-SC-4-R-TR1 C310T-SC-4-R-TR2 C310T-SC-5-R C310T-SC-5-R-TR1 C310T-SC-5-R-TR2 C310T-SC-6.3-R C310T-SC-6-3-R-TR1 C310T-SC-6-3-R-TR2 C310T-SC-8-R C310T-SC-8-R-TR1 C310T-SC-8-R-TR2 6 www.eaton.com/electronics C310T-SC 3.6 mm x 10 mm Time-delay, axial lead ceramic tube fuses Technical Data 10404 Effective December 2019  Wave solder profile tp Tp Temperature First wave Second wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Reference EN 61760-1:2006 Profile feature Preheat Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Manual solder +350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10404 PCN19017M December 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
C310T-SC-2-R-TR1 价格&库存
很抱歉,暂时无法提供与“C310T-SC-2-R-TR1”相匹配的价格&库存,您可以联系我们找货
C310T-SC-2-R-TR1
    C310T-SC-2-R-TR1
      • 1500+1.58591
      • 3000+1.53087
      • 4500+1.46326
      • 7500+1.38419
      • 15000+1.13608
      C310T-SC-2-R-TR1
      • 1500+1.36629
      • 3000+1.35420
      • 4500+1.33001
      • 7500+1.28165
      • 15000+1.05192
      库存:15000
