Effective June 2017
Supersedes December 1998
Technical Data 2059
SFE
Automotive fast-acting glass fuse
Time-Current Characteristics–Total Clear
SFE-6
6
3/4
19.0
SFE-7-1/2
7 1/2
7/8
22.2
SFE-9
9
7/8
22.2
SFE-14
14
1-1/16
27.0
SFE-20
31.7
SFE-30
30
1-7/16
36.5
0.25"
10
Product features
For automotive circuits.
Visual indicating glass tubing.
Made to SAE specifications.
32 V, 4 A – 30 A
Physical size varies with electrical rating of fuse to prevent
over-fusing.
For mounting in in-line holders, and 1/4” clips.
AMPERE
RATING
30
15.9
14
4
9
mm
SFE-4
100
4
“A”
Length
Inches
6
Part number
Current
rating
(A)
TIME IN SECONDS
A
7.5
Dimensional Data
1
.1
Agency information
2,000
1,000
100
10
.01
4
U.L. LISTED: GUIDE #FHXT, FILE #AU169)
CURRENT IN AMPERES
In-line Fuseholders
Catalog Number
Wire
Length
Fuse
Fuse &
Holder (w/leads)
Holder Only
(No Leads)
SFE-20
HRJ
*HHJ-A, HHJ-B
19”
SFE-14
HRI
*HHI-A, HHI-B
(#14
SFE-9
HRH
HHH-A
Wire)
Carton Quantity and Weight
Carton
Qty
Weight*
Lbs.
Kg.
SFE-4
100
0.73
0.331
Part number
SFE-7-1/2
HRE
HHH-A
SFE-6
HRG
HIG-A
SFE-6
100
0.75
0.340
SFE-4
HRF
HIR-A
SFE-7-1/2
100
0.80
0.363
SFE-20
HMJ
*HDJ-A, HDJ-B
SFE-9
100
0.80
0.363
8”
SFE-14
HMI
*HDI-A, HDI-B
(#14
SFE-9
HMH
SFE-14
100
0.82
0.372
Wire)
SFE-7-1/2
HME
SFE-20
100
0.87
0.395
SFE-6
HMG
SFE-30
100
1.60
0.762
SFE-4
HMF
*-A: Crimp connections for #18 - #22 wire.
-B: Crimp connections for #12 - #16 wire.
* Weight per carton.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 2059 SB98107
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“BK/SFE-4”相匹配的价格&库存,您可以联系我们找货
