Electronic — PCB & Small Dimension Fuses
5 x 20mm European (IEC) ferrule fuses
S500-V (GDB-V) (axial leads)
S501-V (GDA-V)
S500 (GDB)
S501 (GDA)
S506 (GDC)
Specifications
Description: Fastacting, low-breaking
capacity fuse.
Construction:
Glass tube, nickelplated brass endcaps.
Ratings:
Volts — 250Vac (or less)
Amps — 32mA-16A
IR — 35A @ 250Vac
Agency Information: CE, Designed to
IEC 60127-Sheet II British Standard
Approval SEMKO Approval VDE
Approval, IMQ UL Recognized, Guide
JDYX2, File E19180, 32mA-6.3A.
Specifications
Description: Fastacting, high-breaking capacity fuse.
Construction:
Ceramic tube, nickel-plated brass endcaps.
Ratings:
Amps — 50mA-6.3A
IR — 1500A @ 250Vac
Agency Information: CE, UL
Recognized, Guide JDYX2, File
E19180, 50mA and 315mA-6.3A
SEMKO Approval 50mA, 200mA and
315mA-6.3A, IEC 60127-Sheet I, VDE
Approval 1.25A-6.3A.
Specifications
Description: Timedelay, low-breaking
capacity fuse.
Construction:
Ratings:
Amps — 32mA-6.3A
IR — 35A @ 250Vac
to IEC 60127-Sheet III British
Standard Approval SEMKO Approval
VDE Approval, IMQ UL Recognized,
Guide JDYX2, File E19180,
32mA-6.3A.
Typical Applications
• Electronic Circuits
Catalog Numbers (Amps)
Catalog
Numbers
I2t
Max Voltage
Drop (mV)
S500-32
0.000047
S500-40
0.00011
S500-50
0.00020
S500-63
0.00057
S500-80
0.0012
S500-100
0.003
S500-125
0.005
S500-160
0.008
S500-200
0.016
S500-250
0.028
S500-315
0.058
S500-400
0.018
S500-500
0.018
S500-630
0.035
S500-800
0.067
S500-1
0.60
S500-1.25
0.84
S500-1.6
1.6
S500-2
4.2
S500-2.5
6.1
S500-3.15
13
S500-4
22
S500-5
42
S500-6.3
69
S500-8*
S500-10*
S500-12*
S500-16*
*IEC Standard 127 Sheet II does not include ratings above 6.3A.
10000
8000
3200
2500
2200
2100
2000
1950
1600
1400
1150
950
220
220
180
200
200
190
160
145
130
120
115
110
Options
Axial leads, put “V” in P/N,
RoHS compliant, put “R” suffix in P/N.
Example: S500-V-1.25-R.
Data Sheet: 2015
Features and Benefits
• Fast-acting for maximum protection.
• High break capacity for use in higher
fault energy electronic circuitry.
• Conforming to IEC standards.
Catalog
Numbers
S501-50
S501-63
S501-80
S501-100
S501-125
S501-160
S501-200
S501-250
S501-315
S501-400
S501-500
S501-630
S501-800
S501-1
S501-1.25
S501-1.6
S501-2
S501-2.5
S501-3.15
S501-4
S501-5
S501-6.3
I2t
0.0017
0.0005
0.0011
0.0018
0.0037
0.008
0.020
0.027
0.010
0.018
0.038
0.064
0.097
0.480
0.9
1.9
2.0
3.9
8.1
14
25
48
Max Voltage
Drop (mV)
9000
3300
2600
2300
1900
1600
1350
1300
1400
1200
1050
1200
490
230
200
180
205
190
160
160
155
150
Options
Example: S501-V-1.25-R.
Data Sheet: 2014
S506-V (GDC-V)
(axial leads)
• Time-delay compatibility for inductive
circuits.
Catalog
Numbers
S506-32
S506-40
S506-50
S506-63
S506-80
S506-100
S506-125
S506-160
S506-200
S506-250
S506-315
S506-400
S506-500
S506-630
S506-800
S506-1
S506-1.25
S506-1.6
S506-2
S506-2.5
S506-3.15
S506-4
S506-5S506-6.3
I2t
0.0014
0.0034
0.006
0.012
0.015
0.022
0.034
0.052
0.078
0.17
0.41
0.61
0.75
1.3
3.1
3.6
7
10
17
34
56
91
133
270
Max Voltage
Drop (mV)
1050
920
800
760
580
490
390
320
340
270
250
210
168
158
132
85
80
80
80
80
75
75
75
65
Options
Example: S506-V-1.25-R.
Data Sheet: 2016
For product data sheets, visit www.cooperbussmann.com/products/datasheet.asp
55
Electronic
Fuses
• Fast-acting for maximum protection,
conforms to IEC standards.
(axial leads)
很抱歉,暂时无法提供与“BK/S500-630-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.52694
- 200+0.20391
- 500+0.19678
- 1000+0.19322
