1/4" x 1-1/4" Fuses
MDL Series, Time Delay, Glass Tube
Description
• Time delay, glass tube
• Optional axial leads available
• 1/4 x 1-1/4 (6.3mm x 32mm) physical size
• Glass tube, nickel-plated brass endcap construction
• UL Listed product meets standard 248-14
RoHS
2002/95/EC
ELECTRICAL CHARACTERISTICS
Amp Rating
Opening Time
Rated Current
100%
None
1/16 - 30A
135%
60 minutes max.
200%
120 seconds max.
1/16 - 3A
200%
5 seconds min.
3-2/10 - 8A
200%
12 seconds min.
Dimensions (mm⁄in)
Drawing Not to Scale
Agency Information
• UL Listed Card: MDL 1/16 - 8A (Guide JDYX, File E19180)
• UL Recognized Card: MDL 9 - 30A (Guide JDYX2,
File E19180)
• CSA Certification Card: MDL 1/16 - 8A
(Class No. 1422-01)
• CSA Component Acceptance: MDL 9-30A
(Class No. 1422-30)
Environmental Data
• Shock: 1/100A and 8/10A – MIL-STD-202,
Method 213, Test Condition I; 1A thru 30A –
MIL-STD-202, Method 207, (HI Shock)
• Vibration: 1/100A and 8/10A – MIL-STD-202,
Method 201; 1/4A thru 30A – MIL-STD-202,
Method 204, Test Condition C (Except 5g, 500HZ)
Ordering
• Specify packaging, product, and option code
Product Code
MDL-1/16
MDL-1/10
MDL-1/8
MDL-3/16
MDL-2/10
MDL-1/4
MDL-3/10
MDL-3/8
MDL-1/2
MDL-3/4
MDL-1
MDL-1-1/4
MDL-1-1/2
MDL-2
MDL-2-1/4
MDL-2-1/2
MDL-3
MDL-4
MDL-5
MDL-6
MDL-6-1/4
MDL-7
MDL-8
MDL-9
MDL-10
MDL-15
MDL-20
MDL-25
MDL-30
Voltage
Rating
AC
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
32V
32V
32V
32V
32V
32V
SPECIFICATIONS
250V
35A
35A
35A
35A
35A
35A
35A
35A
35A
35A
35A
100A
100A
100A
100A
100A
100A
200A
200A
200A
200A
200A
200A
AC Interrupting
Rating*
125V
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
10000A
32V
1000A
1000A
1000A
1000A
1000A
1000A
Typical DC Cold
Resistance**
(ohms)
38.000
15.900
9.850
4.680
4.115
3.200
2.300
2.800
1.725
0.822
0.525
0.320
0.250
0.173
0.068
0.096
0.067
0.035
0.023
0.018
0.018
0.018
0.011
0.009
0.008
0.006
0.002
0.001
0.001
Interrupting Ratings (Interrupting ratings were measured at 70% - 80% power factor on AC)
DC Cold Resistance (Measured at ≤10% of rated current)
Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage.)
Typical Voltage Drop (Voltage drop was measured at 25°C±3°C ambient temperature at rated current)
Typical
Melting I2t†
AC
0.0046
0.0420
0.0422
0.116
0.314
0.447
0.412
0.982
1.656
4.343
11.498
86.2
22.7
62.3
49.6
63.1
67.5
19.3
32.0
37.4
38.7
42.7
47.8
51.5
64.4
354.0
2914.0
15221.0
15581.0
Typical
Voltage
Drop‡
2.79
1.95
1.52
1.05
0.972
0.965
0.808
1.46
1.27
1.01
0.995
0.722
0.721
0.644
0.535
0.410
0.345
0.187
0.160
0.155
0.152
0.140
0.119
0.124
0.114
0.130
0.530
0.30
0.40
1/4" x 1-1/4" Fuses
TIME CURRENT CURVE
PACKAGING CODE
Packaging Code
BK
BK1
BK8
Description
100 pieces of fuses packed into a cardboard carton
1,000 pieces of fuses packed into a cardboard carton
8,000 pieces of fuses packed into a cardboard carton
OPTION CODE
Option Code
B
V
-R
Visit us on the web at:
www.cooperbussmann.com
OC-2546 3/07
© Cooper Electronic
Technologies 2007
Description
Board Washable - Hermetically sealed to withstand aqueous cleaning
Axial leads - copper tinned wire with nickel plated brass overcaps
RoHS compliant version
North America
Cooper Electronic Technologies Cooper Bussmann
1225 Broken Sound Parkway NW P.O. Box 14460
Suite F
St. Louis, MO 63178-4460
Boca Raton, FL 33487-3533
Tel: 1-636-394-2877
Tel: 1-561-998-4100
Fax: 1-800-544-2570
Fax: 1-561-241-6640
Toll Free: 1-888-414-2645
Europe
Cooper Electronic Technologies Cooper Electronic Technologies
Cooper (UK) Limited
Avda. Santa Eulalia, 290
Burton-on-the-Wolds
08223
Leicestershire • LE12 5TH UK
Terrassa, (Barcelona), Spain
Tel: +44 (0) 1509 882 737
Tel: +34 937 362 812
Fax: +44 (0) 1509 882 786
+34 937 362 813
Fax: +34 937 362 719
Asia Pacific
1 Jalan Kilang Timor
#06-01 Pacific Tech Centre
Singapore 159303
Tel: +65 278 6151
Fax: +65 270 4160
很抱歉,暂时无法提供与“BK/MDL-25”相匹配的价格&库存,您可以联系我们找货
