BK/S500-10-R
BK/S500-10-R
    EATON(伊顿)
    D5.2xL20mm
    一次性保险丝(熔断) 10A 250V
BK/S500-10-R 数据手册
Electronic — PCB & Small Dimension Fuses 5 x 20mm European (IEC) ferrule fuses S500-V (GDB-V) (axial leads) S501-V (GDA-V) S500 (GDB) S501 (GDA) S506 (GDC) Specifications Description: Fastacting, low-breaking capacity fuse. Construction: Glass tube, nickelplated brass endcaps. Ratings: Volts — 250Vac (or less) Amps — 32mA-16A IR — 35A @ 250Vac Agency Information: CE, Designed to IEC 60127-Sheet II British Standard Approval SEMKO Approval VDE Approval, IMQ UL Recognized, Guide JDYX2, File E19180, 32mA-6.3A. Specifications Description: Fastacting, high-breaking capacity fuse. Construction: Ceramic tube, nickel-plated brass endcaps. Ratings: Volts — 250Vac (or less) Amps — 50mA-6.3A IR — 1500A @ 250Vac Agency Information: CE, UL Recognized, Guide JDYX2, File E19180, 50mA and 315mA-6.3A SEMKO Approval 50mA, 200mA and 315mA-6.3A, IEC 60127-Sheet I, VDE Approval 1.25A-6.3A. Specifications Description: Timedelay, low-breaking capacity fuse. Construction: Glass tube, nickelplated brass endcaps. Ratings: Volts — 250Vac (or less) Amps — 32mA-6.3A IR — 35A @ 250Vac Agency Information: CE, Designed to IEC 60127-Sheet III British Standard Approval SEMKO Approval VDE Approval, IMQ UL Recognized, Guide JDYX2, File E19180, 32mA-6.3A. Typical Applications • Electronic Circuits Catalog Numbers (Amps) Catalog Numbers I2t Max Voltage Drop (mV) S500-32 0.000047 S500-40 0.00011 S500-50 0.00020 S500-63 0.00057 S500-80 0.0012 S500-100 0.003 S500-125 0.005 S500-160 0.008 S500-200 0.016 S500-250 0.028 S500-315 0.058 S500-400 0.018 S500-500 0.018 S500-630 0.035 S500-800 0.067 S500-1 0.60 S500-1.25 0.84 S500-1.6 1.6 S500-2 4.2 S500-2.5 6.1 S500-3.15 13 S500-4 22 S500-5 42 S500-6.3 69 S500-8* — S500-10* — S500-12* — S500-16* — *IEC Standard 127 Sheet II does not include ratings above 6.3A. 10000 8000 3200 2500 2200 2100 2000 1950 1600 1400 1150 950 220 220 180 200 200 190 160 145 130 120 115 110 — — — — Options Axial leads, put “V” in P/N, RoHS compliant, put “R” suffix in P/N. Example: S500-V-1.25-R. Data Sheet: 2015 Features and Benefits • Fast-acting for maximum protection. • High break capacity for use in higher fault energy electronic circuitry. • Conforming to IEC standards. Typical Applications • Electronic Circuits Catalog Numbers (Amps) Catalog Numbers S501-50 S501-63 S501-80 S501-100 S501-125 S501-160 S501-200 S501-250 S501-315 S501-400 S501-500 S501-630 S501-800 S501-1 S501-1.25 S501-1.6 S501-2 S501-2.5 S501-3.15 S501-4 S501-5 S501-6.3 I2t 0.0017 0.0005 0.0011 0.0018 0.0037 0.008 0.020 0.027 0.010 0.018 0.038 0.064 0.097 0.480 0.9 1.9 2.0 3.9 8.1 14 25 48 Max Voltage Drop (mV) 9000 3300 2600 2300 1900 1600 1350 1300 1400 1200 1050 1200 490 230 200 180 205 190 160 160 155 150 Options Axial leads, put “V” in P/N, RoHS compliant, put “R” suffix in P/N. Example: S501-V-1.25-R. Data Sheet: 2014 S506-V (GDC-V) (axial leads) Features and Benefits • Time-delay compatibility for inductive circuits. • Conforming to IEC standards. Typical Applications • Electronic Circuits Catalog Numbers (Amps) Catalog Numbers S506-32 S506-40 S506-50 S506-63 S506-80 S506-100 S506-125 S506-160 S506-200 S506-250 S506-315 S506-400 S506-500 S506-630 S506-800 S506-1 S506-1.25 S506-1.6 S506-2 S506-2.5 S506-3.15 S506-4 S506-5S506-6.3 I2t 0.0014 0.0034 0.006 0.012 0.015 0.022 0.034 0.052 0.078 0.17 0.41 0.61 0.75 1.3 3.1 3.6 7 10 17 34 56 91 133 270 Max Voltage Drop (mV) 1050 920 800 760 580 490 390 320 340 270 250 210 168 158 132 85 80 80 80 80 75 75 75 65 Options Axial leads, put “V” in P/N, RoHS compliant, put “R” suffix in P/N. Example: S506-V-1.25-R. Data Sheet: 2016 For product data sheets, visit www.cooperbussmann.com/products/datasheet.asp 55 Electronic Fuses Features and Benefits • Fast-acting for maximum protection, conforms to IEC standards. (axial leads)
BK/S500-10-R 价格&库存
很抱歉,暂时无法提供与“BK/S500-10-R”相匹配的价格&库存,您可以联系我们找货
BK/S500-10-R
  • 100+23.22682
  • 1000+7.23042
库存:15
