Effective October 2021
Supersedes August 2019
Technical Data 2052
S500
5 mm x 20 mm Fast-acting glass tube fuses
HALOGEN
Pb HF
FREE
Agency information
Product features
cURus: File E19180, Guide JDYX2, JDYX8
CSA Component Acceptance: File1803366
SEMKO Approval: File 414552
VDE Approval: File 40014109
BSI Approval: File KM55676
IMQ Approval: File CA03.00097
CCC Approval: File 2005010207155694
Ordering information
Fast-acting, low breaking capacity
Optional axial leads available
5 mm x 20 mm physical size
Glass tube with silver-plated (32-125 mA) and nickelplated (160 mA-10 A) endcaps
• Designed to IEC 60127-2/2 (160 mA-10 A)
Specify product code
Insert packaging code prefix before part number. E.g.. BK-S500-32-R
Ratings above 6.3 A have a 0.8 mm diameter lead (axial lead)
Specify option code if desired
For axial leads, insert “V” between part number family and
amp rating. E.g. S500-V-100-R
Electrical characteristics
1.5 I n 2.1 I n
2.75 I n
4 In
10 I n
In
min
max
min
max
min
max
max
32 mA-125 mA 60 min 30 min 10 ms 500 ms 3 ms 100 ms 20 ms
160 mA-6.3 A 60 min 30 min 50 ms 2 sec 10 ms 300 ms 20 ms
8 A-10 A
30 min 30 min 50 ms 2 sec 10 ms 400 ms 40 ms
Voltage Interrupting rating
Part number rating (A) at rated voltage
(50 Hz) Vac
Vac
S500-32-R
250
35
S500-40-R
250
35
S500-50-R
250
35
S500-63-R
250
35
S500-80-R
250
35
S500-100-R
250
35
S500-125-R
250
35
S500-160-R
250
35
S500-200-R
250
35
S500-250-R
250
35
S500-315-R
250
35
S500-400-R
250
35
S500-500-R
250
35
S500-630-R
250
35
S500-800-R
250
35
S500-1-R
250
35
S500-1.25-R
250
35
S500-1.6-R
250
35
S500-2-R
250
35
S500-2.5-R
250
35
S500-3.15-R
250
35
S500-4-R
250
40
S500-5-R
250
50
S500-6.3-R
250
63
S500-8-R
250
80
S500-10-R
250
100
Specifications
Typical DC
cold resistance
(Ω)*
290
210
150
113
22
18
11
9.1
6.8
4.3
3.1
2.0
0.26
0.20
0.14
0.125
0.096
0.066
0.043
0.034
0.025
0.021
0.014
0.010
0.010
0.008
Typical
Maximum
voltage
Agency approvals
melting I2t
drop (mV)‡ cURus CSA CCC BSI VDE SEMKO IMQ
AC†
0.00002
13000
11500
0.00006
10500
0.00010
9800
0.00020
3000
0.0008
2800
0.0013
2200
0.0034
0.008
2000
X
X
X
X
X
X
X
0.016
1700
X
X
X
X
X
X
X
0.28
1400
X
X
X
X
X
X
X
0.58
1300
X
X
X
X
X
X
X
0.18
1100
X
X
X
X
X
X
X
0.18
220
X
X
X
X
X
X
X
0.35
220
X
X
X
X
X
X
X
0.67
190
X
X
X
X
X
X
X
0.60
200
X
X
X
X
X
X
X
0.84
200
X
X
X
X
X
X
X
1.6
190
X
X
X
X
X
X
X
4.2
150
X
X
X
X
X
X
X
6.1
150
X
X
X
X
X
X
X
13
130
X
X
X
X
X
X
X
22
130
X
X
X
X
X
X
X
42
120
X
X
X
X
X
X
X
69
120
X
X
X
X
X
X
X
N/A
120
X
X
X
X
X
N/A
120
X
X
X
X
X
* DC cold resistance (Measured at
很抱歉,暂时无法提供与“BK/S500-160-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.53501
- 200+0.59400
- 500+0.57316
- 1000+0.56290
